Setting up Fields
Fields meta-data is maintained via the
Fields
Menu Item from the
Admin Menu
. Fields may describe columns on a table or they may be labels or work fields that do not appear on a table.
Fields - Main
Fields - Tables Using Field
Parent topic
Defining Generator Tools Metadata
This site works best with JavaScript enabled
