Standards
• When adding a new data, the owner flag value of the environment must prefix certain fields of these tables. For example, when a developer adds a new algorithm type to an Oracle Utilities Business Intelligence development environment B1 should prefix the new Algorithm Type code. The fields that are subject to this rule are listed in Standard Data Fields property.
• The data that is already in these tables are not allowed for modification if the data owner is different from your environment owner. This is to prevent the developers from accidentally modifying system data that belong to Oracle Utilities Application Framework or other Base products. However, some fields are exempt from this rule and can be modified by Customer Modification. These fields are listed in Customer Modification Fields property.
Starting V2.2, we introduce a new system data upgrade rule - override Owner flag. If duplicate data rows (data row with same primary key values) found at the time of upgrade, the owner flag values will get overridden. The lower level application system data will override the upper level system data. For example, F1 overrides C1, F1&C1 overrides CM etc. This rule will be applied to the following tables: CI_​CHAR_​ENTITY, CI_​MD_​MO_​ALG, F1_​BUS_​OBJ_​ALG, F1_​BUS_​OBJ_​STATUS_​ALG, CI_​MD_​MO_​OPT, F1_​BUS_​OBJ_​OPT, F1_​BUS_​OBJ_​STATUS_​OPT, F1_​BUS_​OBJ_​STATUS, F1_​BUS_​OBJ_​STATUS_​L
