Development and Implementation System Tables
This chapter defines the standard for the system tables that contain data that are for the application development. The data in these tables implement business logic and UI functions shared by various products and product extensions in the same database.
Standards
Algorithm Type
Algorithm
Application Security
Batch Control
Business Object
Business Service
Characteristics
Data Area
Display Icon
Foreign Key Reference
Lookup
Map
Messages
Meta data - Table and Field
Meta data - Constraints
Meta data - Menu
Meta data - Program, Location and Services
Meta data - Maintenance Object
Meta data - Work Tables
Meta data - Search Object
Navigation Option
Portal and Zone
Sequence
Schema
Script
To do Type
XAI configuration
XAI Services
Parent topic
Guidelines for System Table Updates
