Hooking into UI Javascript User Exits
UI pages can have various events extended in order to add to or possibly override base product behavior. To create a Javascript user exit:
- Identify the page to extend.
- Create a JSP extension file (.xjs file) for the given page containing the necessary method for the given action.
- Identify user exits to code.
- Code the desired user exit logic into the JSP extension file.
