Product Single Fixes
When single fixes to products are released, the following should be done for projects for which the single fixes are required:
  • Stabilize the project by making sure that the project is in a stable state and that all developers have submitted all code to the repository.
  • Apply the single fix to the project repository.
  • Each developer of the project must then synchronize with the project repository.
