Test default actions on Maintenance Class
In addition, all defaults that are registered for a page maintenance must also be tested. This should be done through separate tester methods for each default, calling the FW support method public PageBody executeDefault(PageBody pageBody, String defaultValue)
public void testDefaultChg() {
PageBody input = new PageBody();
// TODO populate inputs for default
// e.g.
input.put(Maintenance.STRUCTURE.FK, "FK CODE");
PageBody output = executeDefault(input, Maintenance.DEFAULTS.CHG);
// TODO compare the outputs
// e.g.
assertEquals("FK Description",
output.get(Maintenance.STRUCTURE.FK_DESCR));
Here is an example to test the default on a field under a list.
public void testDefaultAlogrithm() {
ItemList itemList = input.newItemList
(Maintenance.STRUCTURE.list_MRRA.name);
ListBody listBody = itemList.newListBody();
listBody.put(Maintenance.STRUCTURE.list_MRRA.MRR_ACTN_ALG_CD,
"MRRCRESVCCC");
PageBody output = executeDefault(input, Maintenance.DEFAULTS.AAD);
ItemList outList = output.getList
ListBody body = (ListBody) outList.getList().get(0);
assertEquals(body.get(Maintenance.STRUCTURE.list_MRRA.MRRA_DESCR),
"Create Service Customer Contact");
The input page body should be populated with the expected inputs for the default action, while the output should be compared against the expected output.
