Lookup Naming Guidelines
Here are guidelines for naming Lookups (on the Lookup Field maintenance):
Be specific- the name MUST be unique across all lookups
Don't include a final standard suffix Flag or Lookup (The suffix Lookup is automatically added by the generator to the classes generated for each Lookup field.)
Examples:
WO_STATUS_FLG -> writeOffStatus
STM_RTG_METH_FLG -> statementRoutingMethod
Here are guidelines for naming Lookups Value properties (on Lookup Value maintenance):
Try to word the name in a way that makes sense when prepended by is, and is also valid when standing alone as a constant. (eg {isComplete, COMPLETE}, {isFrozen, FROZEN})
The name might match the english description of the lookup value.
Examples:
HOW_TO_USE_FLG : - -> subtractive
ITEM_STATUS_FLG : A -> active
DGRP_PRIO_FLG : 10 -> highest10
DGRP_PRIO_FLG : 20 -> priority20
