Batch Program generateJavadoc.bat
Property |
Detail |
Purpose |
Create javadocs from custom source code. |
Description |
This script runs the javadoc tool bundled with the jdk against CM source code in the standard directory and targets the javadocs directory. To integrate the javadocs with the product's javadocs the reindex tool needs to be run. |
Usage |
generateJavadoc.bat |
Parameters |
None. |
