Change Template Code in Program Components
The meta-data on the database for the CM JSP program component pages needs to point to the new XSLT template codes. There is a set of SQL scripts that update all the CM tree and sub panel program components with the correct template.
Run the SQLs in the script changeTemplateCodesTTRAndPN.sql against your database to perform this change.
