The Software Development Kit Client
The Software Development Kit client is installed in SDK/<version>.
Folder structure for the SDK client
The SDK folder has the following scripts at the top level:
Scripts in SDK client folder
Additionally, a copy of Eclipse is installed later into the eclipse directory.
Note: Updates are unique versions of the Software Development Kit and therefore have their own directories.
Note: A separate copy of Eclipse is installed per version of the Software Development Kit client because each version may have its own set of plug-ins and the plug-ins must be in the plugins directory of Eclipse.
All of these files are not meant to be executed directly by the developer and are intended to be executed through scripts in the shortcuts folder.
The setsdkenv.bat script specifies the OUAF SDK version version and installation folder.
The setplenv.bat scriptsets up the environment variables needed to correctly run a development environment for the application server.
Note: A copy of Eclipse is installed later into the eclipse directory. This folder is created when the user first runs the startEclipse shortcut script. A separate copy of Eclipse is installed per version of the Software Development Kit client because each version may have its own set of plug-ins, and the plug-ins must be in the plugins directory of Eclipse.
