Jump to main content
Oracle Utilities Application Framework Software Development Kit
Search
Home
Developer Guide
Public API
Java User Exits (interceptors) Interfaces and Classes
InterceptorError class
void setMessageNumber(BigInteger messageNumber)
User Guide
Developer Guide
Overview
Java Annotations
Public API
SQL Return Codes
Standard Business Methods
Business Entity Public Methods
Maintenance Class Public Methods
UI Javascript User Exits
IAddInterceptor Interface
IChangeInterceptor Interface
IDeleteInterceptor Interface
IReadInterceptor Interface
void setMessageCategory(BigInteger messageCategory)
void setMessageParameters(List messageParameters)
void setMessageParameterTypeFlags(List messageParameterTypeFlags)
InterceptorWarning class
RequestContext Methods
Data Objects
Application Logs
Java Programming Standards
HQL Programming Standards
SQL Programming Standards
Database Design
System Table Guide
Key Generation
Development Performance Guidelines
Packaging Guide
Set the message number (required)
