Filter | Usage |
Browser Cache Filter | Browser Client side caching settings - Used with maxAge - Max Age for pages. |
CSS Stylesheet Direction Filter | CSS Filter |
Doctype Replace Filter | JDOC Filter |
FlushAll Redirect Filter | Cache management utility Filter |
GZip Compression Filter | HTTP 1.1 compression filter |
Header Security Filter | OWASP processing of HTTP headers using SAMEORIGIN |
HTML Comment stripping Filter | Removal of comments from HTTP transmission |
Image Browser Cache Filter | Browser Client side caching settings for image files - Used with maxAgeI - Max Age for Images. |
Image RTL Filter | Right to Left support Filter |
Javascript Comment stripping Filter | Removal of comments from javascript transmission |
Minification Filter | Optimization code |
Privacy Page Redirect Filter | Privacy page redirect to /cm/privacy.html |
Request Context Filter | Generic context Filter |
Rest Security Filter | REST security support |
Security Filter | Generic security filter to delegate security to JEE container |
Timezone Database ContentType Filter | Time zone support |
Parameter | disableCompression |
Description | Enables or disables compression between the Web Application Server and Business Application Server (true or false). |
Ordinality | Mandatory |
Valid Values | [true|false] |
Source | Derived from WEB_ISDEVELOPMENT - Development Environment parameter from ENVIRON.INI. It is highly recommended to set to false for all environment exception is development environments using Oracle Utilities SDK. |
Applicability | Web Application Server |
Example: | <context-param> <param-name>disableCompression</param-name> <param-value>false</param-value> </context-param> |
Parameter | excludePath |
Description | Excludes all the files under a specified directory or specified files from the OUAF's top replace filter i.e., the top replace filter is not applied to the files under the directory or the specified files defined against the exclude path param. |
Ordinality | Optional |
Valid Values | Directory path or Files in a directory |
Source | From custom user exit file(web.xml.topReplace_config.include) for web.xml |
Example: | <filter> <filter-name>Top Replace Filter</filter- name> <filter- class>com.splwg.base.web.utility.TopReplaceFilter</ filter-class> <init-param> <param-name>excludePath</param-name> <param-value>/cm/subCM, /cm/sample.txt, /cm/CMServlet</param-value> </init-param> </filter> |
Parameter | maxAge |
Description | Set the duration (in seconds) to store images, in the Client Cache, from the product on the client browser. |
Valid Values | In accordance with JEE Standards Default: 28850 |
Source | Derived from WEB_MAXAGEI - Image Cache parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | <filter> <filter-name>Image Browser Cache Filter</filter-name> <filter-class>com.splwg.base.web.services.BrowserCacheFilter</filter-class> <init-param> <param-name>maxAge</param-name> <param-value>28850</param-value> </init-param> </filter> |
Description | Set the duration (in seconds) to store page structures from the product, in the Client Cache, on the client browser. |
Valid Values | |
Source | Derived from WEB_MAXAGE - Text Cache parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | <filter> <filter-name>Browser Cache Filter</filter-name> <filter-class>com.splwg.base.web.services.BrowserCacheFilter</filter-class> <init-param> <param-name>maxAge</param-name> <param-value>28850</param-value> </init-param> </filter> |
Parameter | auth-method |
Description | Sets the JEE authentication method for the product. |
Valid Values | [BASIC|CLIENT-CERT|FORM] |
Source | Derived from WEB_WLAUTHMETHOD - Authentication Method parameter from ENVIRON.INI. Depending on the value this may lead to further settings being implemented. • BASIC - Enables the operating system to provide the logon dialog. • CLIENT-CERT - Enables an external solution such as a SSO solution, Kerberos or any security implementing client certificates to provide credentials. • FORM - This instructs the product to implement the following additional settings: • WEB_FORM_LOGIN_PAGE - Default Form Login Page needs to be set to indicate the form to use for online authentication. |
Example: | <login-config> <auth-method>FORM</auth-method> <form-login-config> <form-login-page>/loginPage.jsp</form-login-page> <form-error-page>/formLoginError.jsp</form-error-page> </form-login-config> </login-config> |
Parameter | fieldValuesAge |
Description | Set the duration (in seconds) to hold data in the Server Cache. |
Valid Values | 1 - 2147483647 Default: 3600 |
Source | Defaulted from template. Changes to the value require a Implementing Custom Templates. |
Applicability | Web Application Server, Business Application Server. |
Example: | <env-entry> <description>How long to cache drop down values in seconds</description> <env-entry-name>fieldValuesAge</env-entry-name> <env-entry-type>java.lang.Integer</env-entry-type> <env-entry-value>3600</env-entry-value> </env-entry> |
Parameter | disableUIPageCompression |
Description | Enables or disables compression between the browser and Web Application Server (true or false). |
Example: | <env-entry> <description>Disable UIPage compression</description> <env-entry-name>disableUIPageCompression</env-entry-name> <env-entry-type>java.lang.Boolean</env-entry-type> <env-entry-value>false</env-entry-value> </env-entry> |
