Parameter | calendar.japanese.eras |
Description | This is a set of strings defining the era used in the Japanese calendar. The string is a collection of the following tags (one set per era separated with a ";" delimiter): • name - Name of era • abbr - Era Abberviation • since - Date era starts in ISO format (YYYY-MM-DD) • endDate - Date era ends in ISO format (YYYY-MM-DD) • japAbbr - The Japanese character for the era in Unicode format Note: This feature is only appropriate if the Japanese language pack is also installed. |
Ordinality | Mandatory |
Valid Values | String set by implementations |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value, if desired. |
Applicability | Business Application Server, Background Processing. |
Example: | calendar.japanese.eras=name:Taisho,abbr:T,since:1912-07-30,endDate:1926-12-24,japAbbr:\u5927\u6B63;name:Showa,abbr:S,since:1926-12-25,endDate:1989-01-07,japAbbr:\u662D\u548C; name:Heisei,abbr:H,since:1989-01-08,endDate:,japAbbr:\u5E73\u6210 |
Parameter | com.oracle.ouaf.customer.whitelist.file |
Description | Full directory path to the URL customer’s allow list file to be checked for restricting URLs. |
Ordinality | Optional |
Valid Values | Location of allow list URL file, along with filename. |
Source | Defaulted from the CLOUD_CUSTOM_WHITE_LIST_PATH value in ENVIRON.INI. |
Applicability | Business Application Server |
Example: | com.oracle.ouaf.customer.whitelist.file=@SPLEBASE@/etc/cm_whitelist.xml The installed product base directory is defaulted from SPLEBASE value in ENVIRON.INI |
Parameter | com.oracle.ouaf.consolidatedLog.fileName |
Description | Full path to the consolidated log file to retrieve logs in clustered cloud environments. |
Valid Values | Location of consolidate log file, along with filename. |
Source | Defaulted from the CONSOLIDATED_LOG_DIR value in ENVIRON.INI. |
Example: | com.oracle.ouaf.consolidatedLog.fileName=@SPLEBASE@/etc/cm_whitelist.xml The installed product base directory is defaulted from SPLEBASE value in ENVIRON.INI. |
Parameter | com.oracle.ouaf.dbms.scheduler.schema |
Description | The DBMS scheduler objects will be created in the user/schema specified by the property. This property should match the schema where the DBMS integration package was installed in. |
Valid Values | DB Schema name where DBMS integration package is installed. |
Source | Defaulted from the value in ENVIRON.INI. |
Example: | com.oracle.ouaf.dbms.scheduler.schema=DBSchemaName |
Parameter | com.oracle.ouaf.file.tempstorage.dir |
Description | The file being transferred using the file adapter API will be split into multiple files and stored temporarily in this location. |
Valid Values | Directory path on the server. Default value is: @SPLOUTPUT@/tmp |
Example: | com.oracle.ouaf.file.tempstorage.dir=/ouaf/spl/tempdirectory |
Parameter | com.oracle.ouaf.file.tempstorage.splifilesize |
Description | The file being transferred using the file adapter API will be split into multiple files based on the size specified against this property. |
Valid Values | Size in MB. Default is 50. |
Example | com.oracle.ouaf.file.tempstorage.splitfilesize=75 |
Parameter | com.oracle.ouaf.groovy.precompile.allscripts |
Description | Enables the precompilation of groovy scripts during application startup. |
Valid Values | [true|false] |
Source | Value inherited from templates. Use custom template to set this value, if desired. |
Example | com.oracle.ouaf.groovy.precompile.allscripts=true |
Parameter | com.oracle.ouaf.groovy.precompile.maxWaitTime |
Description | Sets maximum wait time to precompile the pre-configured groovy scripts |
Valid Values | Value in milliseconds |
Example | com.oracle.ouaf.groovy.precompile.maxWaitTime=30000 |
Parameter | com.oracle.ouaf.migrationAssistant.exportDirectory |
Description | Contains a directory specification, using the defined substitution variable @F1_MIGR_ASSISTANT_FILES@, in the allow list. |
Valid Values | Location of the CMA export file on the server. |
Source | Value inherited from templates. Use custom template to set this value. |
Example: | com.oracle.ouaf.migrationAssistant.exportDirectory=@F1_MIGR_ASSISTANT_FILES@/export |
Parameter | com.oracle.ouaf.migrationAssistant.importDirectory |
Valid Values | Location of the CMA import file on the server. |
Example: | com.oracle.ouaf.migrationAssistant.importDirectory=@F1_MIGR_ASSISTANT_FILES@/import |
Parameter | com.oracle.ouaf.migrationAssistant.fileExtension |
Description | Specifies the file extention of the CMA file. |
Valid Values | File Extentions. |
Example: | com.oracle.ouaf.migrationAssistant.fileExtension=cma |
Parameter | com.oracle.ouaf.proxy.password |
Description | Password corresponding to a username set using com.oracle.ouaf.proxy.user property to utilize for senders when the jvm is configured to utilize proxy through variables like http.proxyHost and http.proxyPort. |
Valid Values | Encrypted value obtained using keystore. |
Example: | com.oracle.ouaf.proxy.password=Xds12312SA!@sdf |
Parameter | com.oracle.ouaf.proxy.user |
Description | Plain text user name to utilize for senders when the jvm is configured to utilize proxy through variables like http.proxyHost and http.proxyPort. |
Valid Values | Plain text user name. |
Example: | com.oracle.ouaf.proxy.user=user1 |
Parameter | com.oracle.ouaf.system.database.disableTagging |
Description | This enables (false) or disables (true) the database connection tagging feature. Note: Disabling this feature can reduce monitoring capabilities, disable support for Oracle Audit Vault, disable session resource management in Oracle Real Application Clusters and disable advanced support for Database resource plans. |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to true, if desired. |
Applicability | Web Application Server, Business Application Server, Inbound Web Services, Background Processing. |
Example: | com.oracle.ouaf.system.database.disableTagging=false |
Parameter | com.oracle.ouaf.ui.disableRequiredFieldIndicators |
Description | Specifies if the required field indicators on the application UI map should be disabled. |
Example: | com.oracle.ouaf.ui.disableRequiredFieldIndicators=true |
Parameter | com.oracle.ouaf.uriSubstitutionVariables.file |
Description | Points to the file containing the predefined URI substitution variable list. |
Ordinality | Mandatory for cloud installations. Optional for on premise installations. |
Valid Values | Path of the URI substitution variable list file. |
Source | Value inherited from CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION in the ENVIRON.INI file. The following substitution variables are provided by default in OUAF: • F1_CMA_FILES • F1_BI_EXTRACTS • F1_INTERNAL_FILES • F1_CUST_APP_BASE • F1_PROCESS_DIR • F1_SVC_CATALOG_WSDL_DIR • F1_PDB_EXTRACTS • F1_OPEN_API_BASE_URL |
Example: | com.oracle.ouaf.uriSubstitutionVariables.file=@SPLEBASE@/etc/ substitutionVariableList.xml |
Parameter | com.oracle.ouaf.uriValidation.enable |
Description | Enable URL validation. Restricts external URLs based on white list filename. |
Source | Defaulted from the CLOUD_RESTRICTION_URLS_ENABLE value in ENVIRON.INI. |
Example: | com.oracle.ouaf.uriValidation.enable=false |
Parameter | com.oracle.ouaf.web.allowCORS |
Description | Enable Cross Origin Resource Sharing for UI emebedding. |
Source | Defined based on the parameter ENABLE_CORS being set in ENVIRON.INI file. |
Applicability | Web Application Server |
Example: | com.oracle.ouaf.web.allowCORS=false Note: Ensure that com.oracle.ouaf.web.disableSecureCookie should not be set to true. |
Parameter | com.oracle.ouaf.web.csp.enable |
Description | Enables or disables Content Security Policy response header. |
Source | Inherited from templates. Create custom template to update this setting. |
Example: | com.oracle.ouaf.web.csp.enable=true Note: Content Security Policy is enabled by default. To enable access to resources (such as javascript, CSS etc) from other sources, add the source/sources using the menu option properties related to Content Security Policy or add corresponding user exit include files that hold the source domain details, under $SPLEBASE/templates folder. Content Security Policy can be disabled by setting this value to false. |
Parameter | com.oracle.ouaf.web.cspReporting.enable |
Description | Enables or disables Content Security Policy reporting to view the list of values that are expected to be included in Content Security Policy settings. The values can be viewed in the developer tools console of the web browser being used to access the application. The com.oracle.ouaf.web.csp.enable property should be set to false, when this is set to true. |
Example: | com.oracle.ouaf.web.cspReporting.enable=true |
Parameter | com.oracle.ouaf.web.csp.allowedFrameAnsMaxNumber |
Description | Maximum number of frame ancestors allows in Cross Origin Resource Sharing for UI emebedding. |
Valid Values | Numeric value |
Source | Defined based on the parameter CORS_ALLOWED_FRAME_ANCESTORS_MAX_NUMBER being set in ENVIRON.INI file. |
Example: | com.oracle.ouaf.web.csp.allowedFrameAnsMaxNumber=2 |
Parameter | com.oracle.ouaf.web.disableScreenHideSessionTimeout |
Description | Setting this to true disables the hiding of the application screen visibility upon user session timeout. |
Example: | com.oracle.ouaf.web.disableScreenHideSessionTimeout=false |
Parameter | com.oracle.ouaf.web.disableSecureCookie |
Description | Disables secure cookie in non-SSL environments. |
Source | Defined based on the parameter WEB_WLSSLPORT being set in ENVIRON.INI. |
Example: | com.oracle.ouaf.web.disableSecureCookie=false |
Parameter | com.oracle.ouaf.web.http.allowed.methods.enable |
Description | Enables security constraint by allowing only the HTTP methods that are specified under httpAllowedMethods param in web.xml.template that is derived from HTTP_ALLOWED_METHODS in ENVIRON.INI |
Source | Derived from templates. |
Example: | com.oracle.ouaf.web.http.allowed.methods.enable=false |
Parameter | com.oracle.ouaf.web.userInterfaceStyle |
Description | The style of user experience to be used for OUAF web pages. OUAF support Redwood user experience by default. Old style experience can be enabled by setting appropriate value. |
Valid Values | REDWOOD - Redwood user experience, OPE - Old style user experience. Default: REDWOOD |
Source | Defaulted from the USER_INTERFACE_STYLE value in ENVIRON.INI. |
Example: | com.oracle.ouaf.WEB.userInterfaceStyle=REDWOOD |
Parameter | com.oracle.ouaf.web.oracleGuidedLearningId |
Description | Identifier of Oracle Guided Learning for usage with OUAF application. |
Valid Values | Identifier of Oracle Guided Learning. |
Source | Defaulted from the ORACLE_GUIDED_LEARNING_ID value in ENVIRON.INI. |
Example: | com.oracle.ouaf.web.oracleGuidedLearningId=4f3gf3sjf |
Parameter | com.oracle.ouaf.whitelist.file |
Description | Full directory path to the URL oracle allow list file to be checked for restricting URIs. |
Ordinality | Mandatory if restriction is activated. |
Valid Values | Location of whitelist URI file, along with filename. |
Source | Defaulted from the CLOUD_WHITE_LIST_PATH value in ENVIRON.INI. |
Example: | com.oracle.ouaf.whitelist.file=@SPLEBASE@/etc/whitelist.xml |
Parameter | com.oracle.XPath.LRUSize |
Description | Sets Maximum XPath queries cached used in Schema based objects. |
Valid Values | 0 - No queries cached, -1 - Unlimited (7k per query), Value - Number of queries. |
Source | Uses XQUERIES_TO_CACHE - Size of XQuery Cache value in ENVIRON.INI. |
Example: | com.oracle.XPath.LRUSize=2000 |
Parameter | com.oracle.XPath.flushTimeout |
Description | Sets time (in seconds) to reset XPath cache. |
Valid Values | 0 - Never auto flush, Value - Time in seconds between flushes. |
Source | Uses XQUERY_CACHE_FLUSH_TIMEOUT - Cache Life for XQueries value in ENVIRON.INI. |
Example: | com.oracle.XPath.flushTimeout=86400 |
Parameter | com.splwg.batch.cluster.jvmName |
Description | Sets name for monitoring purposes for online batch JVM for online submission. This value is not used by the runtime, just exposed to the JMX interface for categorization purposes. |
Valid Values | Any string without embedded blanks. |
Source | Use the spl.properties.root.exit.include User Exit Include Files to set this value. |
Example: | com.splwg.batch.cluster.jvmName=onlineBatch |
Parameter | com.splwg.batch.scheduler.daemon |
Description | Enable or Disable the Batch Daemon for online submission. The Batch Daemon is used to detect Pending Batch Submission objects and send them to Batch Online servers. It is highly recommended to specify a value of false for Production environments. The Batch Daemon is only recommended to be used, set to true, in Testing, Development or Demonstration environments. |
Source | |
Example: | com.splwg.batch.scheduler.daemon=false |
Parameter | com.splwg.grid.executionMode |
Description | Sets the execution mode of the online Batch submission. |
Valid Values | [THIN|CLUSTERED] |
Source | Derived from BATCH_MODE - Default Mode of Batch parameter from ENVIRON.INI. |
Example: | com.splwg.grid.executionMode=CLUSTERED |
Parameter | com.splwg.grid.online.enabled |
Description | Enable or Disable the Batch Server for online submission. The Batch Server is reponsible for managing and executing jobs allocated by the Batch Daemon. It is highly recommended to specify a value of false for Production environments. Note: The Batch Server is only recommended to be used in Testing, Development or Demonstration environments. |
Source | Derived from BATCHENABLED - Whether Online Batch Server is Enabled parameter from ENVIRON.INI. |
Example: | com.splwg.grid.online.enabled=false |
Parameter | com.splwg.grid.distThreadPool.threads.DEFAULT |
Description | Maximum number of concurrent threads used to execute online submission. This setting is used in conjunction with the Online Batch Server setting. |
Valid Values | 1 - 1000. Default: 5 |
Source | |
Example: | com.splwg.grid.distThreadPool.threads.DEFAULT=5 |
Parameter | com.splwg.schema.newValidations.F1 |
Description | Sets behavior of schema validations. Internal use only. This is set by individual products and should not be altered unless otherwise instructed by Oracle Support. |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to false, if desired. |
Applicability | Web Application Server, Business Application Server. |
Example: | com.splwg.schema.newValidations.F1=true |
Parameter | jmx.remote.x.access.file |
Description | Sets relative location of JMX access control file holding the valid user. Refer to JMX Security for more details. |
Valid Values | Relative location of file from $SPLEBASE. Defaults to scripts/ouaf.jmx.access.file |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to the desired location and file, if desired. |
Applicability | Web Application Server, Business Application Server |
Example: | jmx.remote.x.access.file=scripts/ouaf.jmx.access.file |
Parameter | jmx.remote.x.password.file |
Description | Sets relative location of JMX password file holding the valid passwords for jmx.remote.x.access.file. Refer to JMX Security for more details. |
Valid Values | Relative location of file from $SPLEBASE. Defaults to scripts/ouaf.jmx.password.file |
Example: | jmx.remote.x.password.file=scripts/ouaf.jmx.password.file |
Parameter | oracle.ouaf.jmx.httpssl.flag |
Description | SSL flag setting for JMX REST. This needs to be set to true for SSL enabled REST. |
Source | Derived from JMX_HTTPSSL_FLAG parameter from ENVIRON.INI. |
Applicability | Web Application Server, Business Application Server, Background Processing |
Example: | oracle.ouaf.jmx.httpssl.flag=false |
Parameter | oracle.ouaf.jmx.httpssl.keypair.passphrase |
Description | Keypair passphrase for keystore used for REST JMX. |
Ordinality | Optional. Required if oracle.ouaf.jmx.httpssl.flag is set to true. |
Valid Values | Encrypted passphrase |
Source | Derived from JMX_HTTPSSL_KEYPAIR_PASSPHRASE parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.httpssl.keypair.passphrase=ENC(23Sd$dvsdva@&sdgsdfg) |
Parameter | oracle.ouaf.jmx.httpssl.keystore.file.path |
Description | File path to the keystore used for REST JMX. |
Valid Values | File path |
Source | Derived from JMX_HTTPSSL_KEYSTORE_FILE parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.httpssl.keystore.file.path=/root/keystoreDirectory/keystorefile |
Parameter | oracle.ouaf.jmx.httpssl.keystore.passphrase |
Description | Passphrase for accessing keystore for REST JMX. |
Source | Derived from JMX_HTTPSSL_KEYSTORE_PASSPHRASE parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.httpssl.keystore.passphrase=ENC($3gdijSTR34%&@DFD43F$F) |
Parameter | oracle.ouaf.jmx.httpssl.keystore.type |
Description | Type of keystore used for REST JMX. |
Valid Values | Java supported keystore types. Default is JKS. |
Source | Derived from JMX_HTTPSSL_KEYSTORE_TYPE parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.httpssl.keystore.type=JKS |
Parameter | oracle.ouaf.jmx.httpssl.truststore.filepath |
Description | File path to the trust store used for REST JMX. |
Source | Derived from JMX_HTTPSSL_TRUSTSTORE_FILE parameter from ENVIRON.INI. |
Example | oracle.ouaf.jmx.httpssl.truststore.filepath=/root/truststoreDirectory/truststorefile |
Parameter | oracle.ouaf.jmx.httpssl.truststore.passphrase |
Description | Passphrase to the trust store used for REST JMX. |
Source | Derived from JMX_HTTPSSL_TRUSTSTORE_PASSPHRASE parameter from ENVIRON.INI. |
Example | oracle.ouaf.jmx.httpssl.truststore.passphrase=ENC($3gdijSTR34%&@DFD43F$F) |
Parameter | oracle.ouaf.jmx.httpssl.truststore.type |
Valid Values | Java supported truststore types. |
Source | Derived from JMX_HTTPSSL_TRUSTSTORE_TYPE parameter from ENVIRON.INI. |
Example | oracle.ouaf.jmx.httpssl.truststore.type=JKS |
Valid Values | Relative location of file from $SPLEBASE. Defaults to scripts/ouaf.jmx.password.file. |
Parameter | oracle.ouaf.jmx.remote.startPort |
Description | Alternative port number for JMX monitoring. Allows for overrides from standard port. Overrides spl.runtime.management.rmi.port - JMX Port. |
Valid Values | Valid port numbers. Defaults to spl.runtime.management.rmi.port - JMX Port. |
Example: | oracle.ouaf.jmx.remote.startPort=3200 |
Parameter | oracle.ouaf.jmx.rest.context |
Description | Server context for JMX REST server |
Valid Values | Valid context for JMX REST server |
Source | Derived from JMX_REST_CONTEXT parameter from ENVIRON.INI. |
Applicability | Web Application Server, Business Application Server, Batch Processor |
Example: | oracle.ouaf.jmx.rest.context=amp |
Parameter | oracle.ouaf.jmx.rest.port.batch |
Description | Port number of batch server JMX, for REST service |
Valid Values | Port number |
Source | Derived from JMX_REST_PORT_BATCH parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.rest.port.batch=8080 |
Parameter | oracle.ouaf.jmx.rest.port.service |
Description | Port number of business server JMX, for REST service. |
Source | Derived from JMX_REST_PORT_SERVICE parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.rest.port.service=8080 |
Parameter | oracle.ouaf.jmx.rest.port.web |
Description | Port number of web server JMX, for REST service. |
Source | Derived from JMX_REST_PORT_WEB parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.rest.port.web=8080 |
Parameter | oracle.ouaf.jmx.rest.service.flag |
Description | Setting this to true enables REST service for JMX. |
Source | Derived from JMX_REST_SERVICE_FLAG parameter from ENVIRON.INI. |
Example: | oracle.ouaf.jmx.rest.service.flag=false |
Parameter | oracle.ouaf.jmx.rest.service.host |
Description | Fully qualified host name to run the JMX REST server. |
Valid Values | Servers qualified hostname |
Source | Derived from JMX_REST_SERVICE_HOST parameter from ENVIRON.INI. |
Example | oracle.ouaf.jmx.rest.service.host=localhost |
Parameter | oracle.ouaf.malware.scan.host |
Description | URI for malware scanning of attachments. |
Valid Values | URI |
Source | Value inherited from ENVIRON.INI. |
Example | malwarescanner.custom.serveruri.com |
Parameter | oracle.ouaf.malware.scan.timeout |
Description | Timeout for custom malware scanning of attachments, i.e., the maximum wait time for completing the scan of an attachment using the malware scanner. |
Valid Values | Time in seconds |
Example | 20 |
Parameter | ouaf.accessiblity.features |
Description | Enables or disabled accessibility support from the product, specifically around implementing tabIndex for column headers. Other accessibility features are not altered by this setting. |
Example: | ouaf.accessiblity.features=true |
Parameter | ouaf.attachment.disableSpecialCharCheckOnFileName |
Description | Disables (true) or enables (false) check for special characters used in file name for attachment objects. |
Example: | ouaf.attachment.disableSpecialCharCheckOnFileName=false |
Parameter | ouaf.batch.onlineLogDir |
Description | Sets the location of output from online batch submission and batch scheduler integration. If this property is set, batch logs will be accessible through the Batch Run Tree (application UI). Otherwise, the batch logs download link in the application will be disabled. |
Valid Values | Valid location. Defaults to: $SPLOUTPUT |
Source | Value inherited from BATCH_ONLINE_LOG_DIR - Online Batch Submission Log Directory from ENVIRON.INI. |
Applicability | Background Processing |
Example: | ouaf.batch.onlineLogDir=/tmp |
Parameter | ouaf.batch.onlineLogDir.retain |
Description | Sets the total number of log files that are to be stored for each batch code and thread number. The log files for the particular batch code and thread number will be deleted except for the latest number of logs specified. |
Valid Values | Number. |
Source | Generated by template. Use Configuring Batch Using Bedit to implement a different value. |
Example: | ouaf.batch.onlineLogDir.retain=3 The above example will keep the last three logs and delete the rest |
Parameter | ouaf.database.session.setInstallationTimeZone |
Description | Set this property to true if the Time Zone on the installation record through the online Installation Options - Framework menu item (under Main tab) is different to the default timezone on the database. This will ensure session timezone is corrected. |
Example: | ouaf.database.session.setInstallationTimeZone=false |
Parameter | ouaf.flush.jms.disabled |
Description | Enables (false) or disables (true) Global Cache Flush Support feature. |
Example: | ouaf.flush.jms.disabled=true |
Parameter | ouaf.flush.jms.connection |
Description | JNDI Name for Global JMS connection |
Valid Values | Valid JNDI for JMS Connection Factory. Default: jms/OUFlushConnectionFactory |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to an alternative value, if desired. |
Example: | ouaf.flush.jms.connection=jms/OUFlushConnectionFactory |
Parameter | ouaf.flush.jms.requestTopic |
Description | JNDI Name for Global JMS Request Topic |
Valid Values | Valid JNDI for JMS Request Topic. Default: jms/OUFlushRequestTopic |
Example: | ouaf.flush.jms.requestTopic=jms/OUFlushRequestTopic |
Parameter | ouaf.flush.jms.responseTopic |
Description | JNDI Name for Global JMS Response Topic |
Valid Values | Valid JNDI for JMS Response Topic. Default: jms/OUFlushResponseTopic |
Applicability | Web Application Server, Business Application Server, Inbound Web Services, Background Processing, MOB. |
Example: | ouaf.flush.jms.responseTopic=jms/OUFlushResponseTopic |
Parameter | ouaf.runtime.compatibility.enablePrecisionScaleOnMoney |
Description | Enables or disabled precision checking on money fields. |
Example: | ouaf.runtime.compatibility.enablePrecisionScaleOnMoney=false |
Parameter | ouaf.jmx.com.oracle.ouaf.ws.mbeans.WSFlushBean |
Description | Enables or disables the Flush mbean used for the online JMX monitoring. Refer to the Web Services JMX interface for more information. This parameter is only enabled if the JMX interface is enabled. |
Valid Values | [enabled|disabled] |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to disabled, if desired. |
Applicability | Inbound Web Services |
Example: | ouaf.jmx.com.oracle.ouaf.ws.mbeans.WSFlushBean=enabled |
Parameter | ouaf.jmx.com.splwg.base.support.management.mbean.JVMInfo |
Description | Enables or disables the JVMInfo mbean used for the online JMX monitoring. Refer to the Web Application Server JMX Reference for more information. This parameter is only enabled if the JMX interface is enabled. |
Example: | ouaf.jmx.com.splwg.base.support.management.mbean.JVMInfo=enabled |
Parameter | ouaf.jmx.com.splwg.base.web.mbeans.FlushBean |
Description | Enables or disables the mbean to reset the online data cache manually. Refer to the Web Application Server JMX Reference for more information. This parameter is only enabled if the JMX interface is enabled. |
Example: | ouaf.jmx.com.splwg.base.web.mbeans.FlushBean=enabled |
Parameter | ouaf.list.buffer.limit |
Description | The number of iterations a list is allowed to be read before being truncated. A default of 30 is used, if none or an invalid value is specified for this property. |
Valid Values | Value between 0 – 256: 30 |
Source | Value inherited from JEE container. Use Implementing Custom Templates to set this value, if alternative desired |
Example: | ouaf.list.buffer.limit=30 |
Parameter | ouaf.messaging.transformerfactory |
Description | Sets the transformation factory for the real time adapters. This parameter is only set if requested by Oracle Support. |
Valid Values | Set to one of the following values: com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl org.apache.xalan.xsltc.trax.TransformerFactoryImpl |
Source | Value inherited from container. Use Implementing Custom Templates to set this value, if alternative desired |
Example: | ouaf.messaging.transformerfactory = org.apache.xalan.xsltc.trax.TransformerFactoryImpl |
Parameter | ouaf.shortcut.ignore.altKeys |
Description | Allows specific hot keys to be disabled to support specific keyboard layouts (e.g. Polish keyboards). |
Valid Values | Comma separated list of keys to disable |
Source | Set within template. Use the spl.properties.root.exit.include User Exit Include Files to set this value. |
Example: | ouaf.shortcut.ignore.altKeys=C,L |
Parameter | ouaf.timeout.business_object.default |
Description | Sets the default timeout (in seconds) for Business Objects. Refer to Online Transaction Timeouts for more information. |
Valid Values | 1 - 2147483647 |
Source | Use the spl.properties.service.timeouts.exit.include User Exit Include Files to set this value as outlined in Online Transaction Timeouts. |
Example: | ouaf.timeout.business_object.default=10 |
Parameter | ouaf.timeout.business_object.<bocode> |
Description | Sets the timeout (in seconds) for Business Object designated by <bocode> which corresponds to the Business Object Name. This overrides the ouaf.timeout.business_object.default - Set Default Business Object Timeout setting for the indicated business object. Refer to Online Transaction Timeouts for more information. To find valid values for Business Objects, use the Business Object Maintenance function or use the following SQL using bus_obj_cd for <bocode>: SELECT bus_obj_cd, descr FROM f1_bus_obj_l where language_cd = 'ENG'; The LANGUAGE_CD in the above query can be altered to other languages for language packs installed. |
Example: | ouaf.timeout.business_object.CMUser=10 |
Parameter | ouaf.timeout.business_service.default |
Description | Sets the default timeout (in seconds) for Business Services. Refer to Online Transaction Timeouts for more information. |
Example: | ouaf.timeout.business_service.default=10 |
Parameter | ouaf.timeout.business_service.<bscode> |
Description | Sets the timeout (in seconds) for Business Service designated by <bscode> which corresponds to the Business Service Name. This overrides the ouaf.timeout.business_service.default - Set Default Business Service Timeout setting for the indicated business service. Refer to Online Transaction Timeouts for more information. To find valid values for Business Services, use the Business Service Maintenance function or use the following SQL using bus_svc_cd for <bscode>: SELECT bus_svc_cd, descr FROM f1_bus_svc_l where language_cd = 'ENG'; The LANGUAGE_CD in the above query can be altered to other languages for language packs installed |
Example: | ouaf.timeout.business_service.F1-EmailService=10 |
Parameter | ouaf.timeout.query.default |
Description | Sets the default timeout (in seconds) for query zones (searches and lists). Refer to Online Transaction Timeouts for more information. Use the Zone maintenance function to determine valid values. This setting only applies to the following zone types: F1-DE, F1-DE-MULQRY, F1-DE-QUERY and F1-DE-SINGLE |
Example: | ouaf.timeout.query.default=10 |
Parameter | ouaf.timeout.query.<zonecode> |
Description | Sets the timeout (in seconds) for the online query zone designated by <zonecode> which corresponds to the Query Zone. This overrides the ouaf.timeout.query.default - Set Default Query Timeout setting for the indicated query zone. Refer to Online Transaction Timeouts for more information. This setting only applies to the following zone types: F1-DE, F1-DE-MULQRY, F1-DE-QUERY and F1-DE-SINGLE Use the Zone maintenance function to determine valid values. Alternatively, it is possible to use SQL using zone_cd for <zonecode>: SELECT z.zone_cd, d.descr, z.zone_hdl_cd FROM ci_zone z, ci_zone_l d WHERE z.zone_hdl_cd LIKE 'F1-DE%' AND z.zone_cd = d.zone_cd AND d.language_cd = 'ENG'; The LANGUAGE_CD in the above query can be altered to other languages for language packs installed. |
Example: | ouaf.timeout.business_service.F1-MSTCFGLS=10 |
Parameter | ouaf.timeout.script.default |
Description | Sets the default timeout (in seconds) for Scripts. Refer to Online Transaction Timeouts for more information. |
Valid Values | 1 - 32767 |
Example: | ouaf.timeout.script.default=10 |
Parameter | ouaf.timeout.script.<scriptname> |
Description | Sets the timeout (in seconds) for Scripts designated by <scriptname> which corresponds to the Script Name. This overrides the ouaf.timeout.script.default - Set Default Script Timeout setting for the indicated script. Refer to Online Transaction Timeouts for more information. Note: This timeout does not apply to plug-in scripts. To find valid values for Script, use the Script Maintenance function or use the following SQL using scr_cd for <scriptname>: SELECT s.scr_cd, d.descr254 FROM ci_scr s, ci_scr_l d where s.scr_cd = d.scr_cd and s.scr_type_flg in ('BPSC','SVSC') and d.language_cd = 'ENG'; The LANGUAGE_CD in the query above can be altered to other languages for language packs installed |
Example: | ouaf.timeout.script.F1-ViewWSDL=10 |
Parameter | ouaf.timeout.service.default |
Description | Sets the default timeout (in seconds) for Application Services. Refer to Online Transaction Timeouts for more information. |
Example: | ouaf.timeout.service.default=10 |
Parameter | ouaf.timeout.service.<service> |
Description | Sets the timeout (in seconds) for Application Services designated by <service> which corresponds to the Application Service Name. This overrides the ouaf.timeout.service.default - Set Default Service Timeout setting for the indicated Application Service. Refer to Online Transaction Timeouts for more information. To find valid values for Application Service, use the Application Service Maintenance function or use the following SQL using svc_name for <service>: SELECT SVC_NAME, DESCR from CI_MD_SVC_L where language_cd = 'ENG'; The LANGUAGE_CD in the above query can be altered to other languages for language packs installed |
Example: | ouaf.timeout.service.CILTUSEP=10 |
Parameter | ouaf.web.disablePreload |
Description | Enables or sisables screen preloading at startup. Screens that are preloaded are autoloaded at startup rather than at first use, saving time at runtime for first use transactions. This parameter works in conjunction with ouaf.web.preloadAllPages - Preload Scope. It is highly recommended to set this value to false (default) for Production Environments. It is only suggested to set this to true in development environments that are used in conjunction with the Oracle Utilities SDK. |
Source | Derived from WEB_ISDEVELOPMENT - Development Environment parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended |
Example: | ouaf.web.disablePreload=false |
Parameter | ouaf.web.helpRootURL |
Description | Root part of the URI for online help hosted on Oracle Help Center. |
Valid Values | URI. Value set by the product. Should not be changed. |
Source | Value inherited from templates. |
Example: | ouaf.web.helpRootURL=https://rooturlof.oraclehelpcenter.com/ |
Parameter | ouaf.web.JspHeader.maxAge |
Description | Set the duration (in seconds) to screen HTML, in the Client Cache, from the product on the client browser. |
Valid Values | in accordance with JEE Standards. Default: 28850 |
Source | Derived from WEB_MAXAGE - Text Cache parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | ouaf.web.JspHeader.maxAge=28850 |
Parameter | ouaf.web.preloadAllPages |
Description | Set the scope of the preloading of pages. This parameter is only used if the ouaf.web.disablePreload - Disable Screen Preload is set to false. It is highly recommended to set this value to false (default) for all environments. |
Valid Values | [true|false] Main menu only (false), Main menu and Administration menu (true) |
Source | Derived from WEB_PRELOADALL - Preload All Pages on Startup parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | ouaf.web.preloadAllPages=false |
Parameter | ouaf.weblogic.enableDiagnostics |
Description | Enables (true) or disable (false) ECID Support. |
Example: | ouaf.weblogic.enableDiagnostics=false |
Parameter | ouaf.webservices.security.defaultPolicy |
Description | Sets the customized policy for the deployed IWS. |
Example: | ouaf.webservices.security.defaultPolicy=false |
Parameter | ouaf.ws.defaultUser |
Description | Default user used for authorization for Inbound Web Services if no credentials are provided on the Web Service call. This is provided for backward compatibility for Inbound Web Services. It is recommended not to be set at all, as to enforce stronger security for Web Services. |
Valid Values | Valid authorization user for product. A null or blank value enforces security on each Web Service call. |
Source | Defaulted from templates. Use Implementing Custom Templates to set this value to an alternative desired value. |
Example: | ouaf.ws.defaultUser=AUSER |
Parameter | ouaf.ws.deploy.appxml.file |
Description | Location of application.xml file for Web Services. |
Ordinality | Man |
Valid Values | Valid Path and location. |
Source | Derived from template. This should not be changed. |
Example: | ouaf.ws.deploy.appxml.file=/tmp/iws/resources/application.xml |
Parameter | ouaf.ws.deploy.ear |
Description | Name of EAR file used for Inbound Web Services |
Source | Derived from template Use Implementing Custom Templates to set this value to an alternative desired value |
Example: | ouaf.ws.deploy.ear=Webservices.ear |
Parameter | ouaf.ws.deploy.contextpath |
Description | Default context path used for Inbound Web Services calls |
Source | Derived from template Use Implementing Custom Templates to set this value to an alternative desired value. |
Example: | ouaf.ws.deploy.contextpath=/ouaf/webservices/ |
Parameter | ouaf.ws.pageService.annotations |
Description | The default security WS-Policy annotations attached for legacy page services (XAI) within IWS. To ensure backward compatibility, for customers using XAI legacy services, it is recommended to set this value to the default F1-USERNAM annotation. |
Valid Values | Valid Web Service Annotation |
Example: | ouaf.ws.pageService.annotations=F1-USERNAM |
Parameter | ouaf.ws.superusers |
Description | Sets the effective users for Inbound Web Services. This allows credentials from foreign systems to use credentials from the product. This is only set to alternatives if effective users are used. |
Valid Values | Valid comma separated list of credentials |
Source | Derived from WEB_SPLUSER parameter from ENVIRON.INI. Use Implementing Custom Templates to set this value to an alternative desired value. |
Example: | ouaf.ws.superusers=SYSUSER |
Parameter | ouaf.ws.tools.artifact.generated.buildfile |
Description | Location and name of ant build file used to generate the WAR file used for Inbound Web Services. This setting is used by the iwsdeploy - Inbound Web Services Deployment command as well as the online Inbound Web Services deployment tool. |
Valid Values | Location and name of build file. Defaults to $SPLEBASE/splapp/iws/iws-build.xml |
Source | Derived from SPLDIR - Home Directory of Product parameter from ENVIRON.INI. Use Implementing Custom Templates to set this value to an alternative desired value. |
Example: | ouaf.ws.tools.artifact.generated.buildfile= /spl/OUAFDEMO/splapp/iws/iws-build.xml |
Parameter | ouaf.ws.tools.artifact.generated.sourcedir |
Description | Location of the source generated for Inbound Web Services during the Web Services deployment process. |
Valid Values | Location of generated source directory. Defaults to $SPLEBASE/splapp/iws/gen |
Example: | ouaf.ws.tools.artifact.generated.sourcedir= /spl/OU#AFDEMO/splapp/iws/gen |
Parameter | ouaf.ws.tools.artifact.resource.dir |
Description | Location of the resource files used in the generation of Inbound Web Services during the Web Services deployment process. |
Valid Values | Location of resources used for Inbound Web Services. Defaults to $SPLEBASE/splapp/iws/resources |
Example: | ouaf.ws.tools.artifact.resource.dir= /spl/OUAFDEMO/splapp/iws/resources |
Parameter | ouaf.ws.tools.artifact.schema.dir |
Description | Location of the schema files used in the generation of Inbound Web Services during the Web Services deployment process. |
Valid Values | Location of schema files used for Inbound Web Services. Defaults to $SPLEBASE/splapp/xai/schemas |
Example: | ouaf.ws.tools.artifact.schema.dir= /spl/OUAFDEMO/splapp/xai/schemas |
Parameter | ouaf.ws.tools.artifact.xsl.dir |
Description | Location of the XSLT files used by Inbound Web Services during the Web Services deployment process. This parameter can be overridden using the ouaf.ws.xslDirOverride - Override XSL Location setting. |
Valid Values | Location of XSLT files used for Inbound Web Services. Defaults to $SPLEBASE/splapp/xai/schemas. By default this value is shared with ouaf.ws.tools.artifact.schema.dir - Location of Schemas. |
Example: | ouaf.ws.tools.artifact.xsl.dir= /spl/OUAFDEMO/splapp/xai/schemas |
Parameter | ouaf.ws.tracing |
Description | Enable or Disable tracing for Inbound Web Services. |
Example: | ouaf.ws.tracing=true |
Parameter | ouaf.ws.xslDirOverride |
Description | Location of the XSLT files used by Inbound Web Services during the Web Services deployment process. This parameter overrides the ouaf.ws.tools.artifact.xsl.dir - Web Service XSL Location setting. |
Valid Values | Valid directories on server containing xsl |
Source | Not set. Use Implementing Custom Templates to set this value to an alternative desired value. |
Examples: | ouaf.ws.xslDirOverride=/temp |
Parameter | spl.csv.delimiter.useFromDisplayProfile |
Description | Enables or disables the display of the delimiter for CSV upload/downloads from zones. |
Source | Derived from template. Use Implementing Custom Templates to set this value to true, if desired. |
Example: | spl.csv.delimiter.useFromDisplayProfile=false |
Parameter | spl.ejbContainer.contextFactory |
Description | Default JEE Context Factory to connect tiers. |
Valid Values | Valid connection factory: weblogic.jndi.WLInitialContextFactory |
Source | Derived from template. Use Implementing Custom Templates to set this value to an alternative, if desired. |
Applicability | Web Application Server, Inbound Web Services. |
Example: | spl.ejbContainer.contextFactory= weblogic.jndi.WLInitialContextFactory |
Parameter | spl.ejbContainer.password |
Description | Default encrypted password for tier defined for Business Application Server connections. |
Valid Values | Valid password encryptyed Administration user |
Source | Use Implementing Custom Templates to set this value to an alternative, if desired. |
Example: | spl.ejbContainer.password=ENC(Hi7/RFy…) |
Parameter | spl.ejbContainer.url |
Description | URL to connect to the Business Application Server from the Web Application Server or Inbound Web Services. |
Valid Values | Valid URL for: t3://<server>:<port> or t3s://<server>:<port> |
Example: | spl.ejbContainer.url=t3://localhost:6500 |
Parameter | spl.ejbContainer.user |
Description | Administration user for Business Application server to connect to from the Web Application Server and Inbound Web Services. |
Valid Values | Valid Administration User on Oracle Weblogic |
Example: | spl.ejbContainer.user=system |
Parameter | spl.geocodeDatasource.contextFactory |
Description | Default Context Factory to connect to GIS. This option will only be enabled if GIS is set to true in the ENVIRON.INI. |
Example: | spl.geocodeDatasource.contextFactory= weblogic.jndi.WLInitialContextFactory |
Parameter | spl.geocodeDatasource.password |
Description | Encrypted password for GIS connection for spl.geocodeDatasource.user - GIS Connection User. This option will only be enabled if GIS is set to true in the ENVIRON.INI. |
Valid Values | Encrypted password for GIS. |
Source | Derived from GIS_WLSYSPASS from ENVIRON.INI. |
Example: | spl.geocodeDatasource.password=ENC(Hi7/RFy…) |
Parameter | spl.geocodeDatasource.url |
Description | JNDI name for GIS Data Source. This option will only be enabled if GIS is set to true in the ENVIRON.INI. |
Valid Values | Valid JNDI path for GIS Data Source |
Source | Derived from GIS_WLSYSUSER from ENVIRON.INI. |
Example: | spl.geocodeDatasource.url=t3://localhost:7666/jdbc/gisdb |
Parameter | spl.geocodeDatasource.user |
Description | Valid JNDI user for GIS connection. This option will only be enabled if GIS is set to true in the ENVIRON.INI. |
Applicability | Web Application Server, Business Application Server, Background Processing. |
Example: | spl.geocodeDatasource.user=gisadmin |
Parameter | spl.runtime.compatibility.uiMapDisableInputValue |
Description | Enables or disables compatibility behavior with Oracle Utilities Application Framework V2.1 in relation to blanking out default values in screens. Setting this value to true will emulate Oracle Utilities Application Framework V2.1 behavior. This setting is only applicable to customers who are upgrading from Oracle Utilities Application Framework V2.1 and wish to retain that behavior. |
Source | Manually set. Use user exit spl.properties.exit.include to set this value to true, if desired |
Example: | spl.runtime.compatibility.uiMapDisableInputValue=false |
Parameter | spl.runtime.compatibility.uiMapDropdownSelectFirstValue |
Description | Enables or disables compatibility behavior with Oracle Utilities Application Framework V2.1 in relation to defaulting to the first value in the drop-down list. Setting this value to true will emulate Oracle Utilities Application Framework V2.1 behavior. This setting is only applicable to customers who are upgrading from Oracle Utilities Application Framework V2.1 and wish to retain that behavior. |
Example: | spl.runtime.compatibility.uiMapDropdownSelectFirstValue=false |
Parameter | spl.runtime.compatibility.uiMapDisableTitle |
Description | Enables or disables compatibility behavior with Oracle Utilities Application Framework V2.1 in relation to rendering screen titles. Setting this value to true will emulate Oracle Utilities Application Framework V2.1 behavior. This setting is only applicable to customers who are upgrading from Oracle Utilities Application Framework V2.1 and wish to retain that behavior. |
Example: | spl.runtime.compatibility.uiMapDisableTitle=false |
Parameter | spl.runtime.compatibility.uiMapDisableGenerateUniqueHtmlIDs |
Description | Enables or disables compatibility behavior with Oracle Utilities Application Framework V2.x in relation to generating an unique idenitifer's for HTML for duplicate elements in the screen. In Oracle Utilities Application Framework V2.x (true), duplicate HTML ids were permitted on screen elements. In Oracle Utilities Application Framework V4.x (false), unique ids are generated for screen elements by default. Setting this value to true will emulate Oracle Utilities Application Framework V2.x behavior. This setting is only applicable to customers who are upgrading from Oracle Utilities Application Framework V2.x and wish to retain that behavior. |
Example: | spl.runtime.compatibility.uiMapDisableGenerateUniqueHtmlIDs=false |
Parameter | spl.runtime.customSQLSecurity |
Description | Enables or disables SQL allowlist validations for CM Groovy scripts and data explorer zones. Setting this to true will restrict the SQL in CM data explorer zone to the allow list. Setting this to false will not restrict the SQL in CM data explorer zones. |
Source | Manually set. |
Example: | spl.runtime.customSQLSecurity=false |
Parameter | spl.runtime.disableCSRFProtection |
Description | Enables or disables security token support for testing purposes with testing tools that do not support security tokens. It is highly recommended that this configuration setting be set to false in all environments, especially Production. It should only be set to true in testing environments where test tools are used and the test tool used does not support security tokens. |
Example: | spl.runtime.disableCSRFProtection=false |
Parameter | spl.runtime.environ.init.dir |
Description | Location of the configuration files used for the product. This is used to allow the product to read configuration files at runtime to determine behavior. |
Valid Values | URL is derived from spl.runtime.environ.SPLEBASE with the etc directory appended. |
Source | Derived from cistab - Global Configuration Files file. |
Applicability | Web Application Server, Business Application Server, Inbound Web Services |
Example: | spl.runtime.environ.init.dir=/spl/OUAFDEMO/etc |
Parameter | spl.runtime.environ.isWebExpanded |
Description | Determines whether WAR/EAR files are built [false] or as expanded directories [true]. The expanded mode is used for development purposes only and is only supported on Oracle WebLogic. It is recommended to set this to false to use WAR/EAR files for deployment. |
Source | Derived from WEB_ISEXPANDED parameter from ENVIRON.INI. |
Example: | spl.runtime.environ.isWebExpanded=false |
Parameter | spl.runtime.environ.SPLEBASE |
Description | Home directory of the product installation |
Valid Values | Full expanded directory on machine |
Example: | spl.runtime.environ.SPLEBASE=/spl/OUAFDEMO |
Parameter | spl.runtime.initialize.waittime |
Description | Delay Time (in seconds) for start of application from initiation time. This is used to delay startup to ensure downstream connections are established prior to startup. |
Valid Values | 0 - 3000 (Default: 45) |
Source | Derived from templates. Use Implementing Custom Templates to set this value to an alternative, if desired |
Example: | spl.runtime.initialize.waittime=45 |
Parameter | spl.runtime.environ.SPLOUTPUT |
Description | Home directory of the product output |
Example: | spl.runtime.environ.SPLEBASE=/spl/splapp/OUAFDEMO |
Parameter | spl.runtime.management.batch.cluster.url |
Description | URL for the Batch Cluster |
Valid Values | Valid URL for Batch Cluster |
Source | Derived from WEB_BATCH_CLUSTER_URL parameter from ENVIRON.INI. |
Example: | spl.runtime.management.batch.cluster.url= |
Parameter | spl.runtime.management.connector.url.default |
Description | |
Valid Values | URL is generated from the following settings: Web Application Server WEB_WLHOST and WEB_JMX_RMI_PORT_PERFORMANCE Business Application Server BSN_WLHOST and BSN_JMX_RMI_PORT_PERFORMANCE Inbound Web Services BSN_WLHOST and BSN_JMX_RMI_PORT_PERFORMANCE |
Source | Derived from ENVIRON.INI file. |
Applicability | Web Application Server, Business Application Server, Inbound Web Services. |
Example: | spl.runtime.environ.SPLEBASE= service:jmx:rmi:///jndi/rmi://localhost: 1100/oracle/ouaf/ejbAppConnector |
Parameter | spl.runtime.management.rmi.port |
Description | Port number to be used for JMX Based Monitoring. |
Valid Values | Port Number is generated from the following settings: Web Application Server WEB_JMX_RMI_PORT_PERFORMANCE Business Application Server BSN_JMX_RMI_PORT_PERFORMANCE Inbound Web Services BSN_JMX_RMI_PORT_PERFORMANCE Batch BATCH_RMI_PORT |
Example: | spl.runtime.management.rmi.port=1100 |
Parameter | spl.runtime.options.isFCFEnabled |
Description | Enable or Disable RAC Fast Connection Failover support for database connections. Oracle Notification Services configuration is set by the spl.runtime.options.onsserver=nodes - ONS Configuration parameter. |
Source | Derived from ONSCONFIG parameter from ENVIRON.INI. |
Example: | spl.runtime.options.isFCFEnabled=false |
Parameter | spl.runtime.options.onsserver=nodes |
Description | Specify the Oracle Notification Services (ONS) configuration for Fast Connection Failover support for database connections. Refer to the Oracle Notification Services documentation for details of ONS setup and values for this setting. |
Valid Values | Valid ONS configuration string (without the nodes= prefix) |
Example: | spl.runtime.options.onsserver=nodes=racnode1:4200,racnode2: 4200\nwalletfile= /oracle11/onswalletfile |
Parameter | spl.runtime.options.allowSystemDateOverride |
Description | Allows the user of system test date override feature for testing. Refer to the Setting the Date for Testing Purposes for more information. It is highly recommended that this setting should be set to false in Production environments. |
Source | Manually set. Use custom templates to set this value to true, if desired. |
Example: | spl.runtime.options.allowSystemDateOverride=false |
Parameter | spl.runtime.options.createSimpleWebAppContextEnable |
Description | Enables or disables cache loading from Web Application Server. Setting this value to true will load the server cache through the Business Application Server. If the cache loading, is desired to be loaded within each tier then set this value to false. It is highly recommended that this setting should be set to true in production environments. |
Source | Manually set. Use user exit spl.properties.exit.include to set this value to false, if desired. |
Example: | spl.runtime.options.createSimpleWebAppContextEnable=false |
Parameter | spl.runtime.options.isDevelopmentMode |
Description | Enables or disables Development Mode for the product. Development mode disables and enables key features within the architecture to allow the Oracle Utilities SDK to be used optimally. The following settings are affected by this parameter: • Caching is disabled at all layers of the architecture. This can be renabled manually. • Screen Preloading is disabled. This can be renabled manually. • Compression is disabled at all layers of the architecture. This can be renabled manually. • The product is set to expanded mode to allow developers access to individual JEE objects rather than using WAR/EAR files. It is highly recommended that this setting should be set to false in production environments. This setting is only set to true where the Oracle Utilities SDK is used directly. |
Source | Derived from WEB_ISDEVELOPMENT parameter from ENVIRON.INI. |
Example: | spl.runtime.options.isDevelopmentMode=false |
Parameter | spl.runtime.oracle.statementCacheSize |
Description | Number of SQL statement cached for Java based code. It is highly recommended not to alter this value unless otherwise advised by Oracle Support. |
Valid Values | 1 - 2147483647 (Default: 300) |
Example: | spl.runtime.oracle.statementCacheSize=300 |
Parameter | spl.runtime.performSignedNumberValidation.<product> |
Description | Unsigned Number Validation routine used by product. By default a F1 based routine is provided and this setting allows products to provide their own processing. This setting is provided for products only. Implementations should not set this value. |
Source | Derived from templates. Use User Exit Include Files, spl.properties.service.exit.include and spl.properties.standalone.exit.include to set this value to an alternative, if desired. |
Example: | spl.runtime.performSignedNumberValidation.F1=true |
Parameter | spl.runtime.service.extraInstallationServices |
Description | Specifies the internal service used for checking the installation records at startup time. This setting is used by the products, it is not recommended to be altered, unless otherwise directed by Oracle Support. |
Valid Values | Service Name |
Source | By default the service CILTINCP is used internally |
Example: | spl.runtime.service.extraInstallationServices=CILTINCP |
Parameter | spl.runtime.sql.highValue |
Description | The high value used for paremeters by SQL queries. It is highly recommended not to alter this value unless otherwise advised by Oracle Support. |
Valid Values | Valid high value generated by installer. |
Source | Derived from the HIGHVALUE setting in the ENVIRON.INI. |
Example: | spl.runtime.sql.highValue=\uF8FF |
Parameter | spl.runtime.utf8Database |
Description | Enables or disables UTF8 support within the product. |
Source | Derived from the ENCODING (CHAR_BASED_DB) setting in the ENVIRON.INI. |
Example: | spl.runtime.utf8Database=true |
Parameter | spl.runtime.warning.dialog.before.download |
Description | Enables or disables the warning message display whenever user performs an action that causes data to be copied/downloaded to their local machine. |
Source | Derived from templates. Use custom templates to set this value to an alternative, if desired. |
Example: | spl.runtime.warning.dialog.before.download=true |
Parameter | spl.serviceBean.jndi.name |
Description | JNDI name for Business Application Server generated by installer. It is highly recommended not to alter this value unless otherwise advised by Oracle Support. |
Valid Values | Generated by installer. |
Source | Derived from the WEB_CONTEXT_ROOT setting in the ENVIRON.INI. |
Example | spl.serviceBean.jndi.name=ouaf/servicebean |
Parameter | spl.tools.loaded.applications |
Description | List the internal product codes installed under the Oracle Utilities Application Framework. This setting is maintained by the individual products and should not be altered unless otherwise instructed by Oracle Support. |
Valid Values | Comma separated list of products. |
Source | Maintained by product templates. |
Example | spl.tools.loaded.applications=base,cm |
Parameter | ouaf.propertyfile.usage |
Description | Properties file module usage |
Valid Values | root, rest, service, iws, standalone, tpw, mobile |
Source | Derived from templates |
Applicability | Web Application Server, Business Application Server, Inbound Web Services, Background Processing |
Example | ouaf.propertyfile.usage=root |
