Creating Business Components
Business Components provide a mechanism to provide non-persistent business logic (as opposed to business entities that add to persistent objects). An example business component is as follows:
 * Component used to query for {@link Person} instances based on various
 * predefined criteria.
 * @BusinessComponent
 *   (customizationReplaceable = false)
public class PersonFinders_Impl
    extends GenericBusinessComponent
    implements PersonFinders
     * @param   nameType  a name type
     * @return  count of names by name type
     * @BusinessMethod (customizationCallable = true)
    public int findCountByNameType(Lookup nameType) {
        Query query = createQuery
            ("FROM PersonName name where name.nameType = :type");
        query.bindLookup("type", nameType);
        return (int) query.listSize();
To add a new component:
- Create a new implementation class.
- Specify appropriate annotations for a business component implementation class.
- Code business methods.
- Specify appropriate annotations for business methods.
- Create a JUnit test.
- Generate artifacts.
- Run JUnit tests.
- Deploy to runtime.
- Test in runtime.
