Creating the Implementation Class
There is very little that needs to be done by application developers to create a basic business
entity. In addition to the setup of the CI_MD_* tables describing the entity and its
constraints, only an implementation class (or Impl) needs to be added.
In this case, a developer added Person_Impl. The following is a simple
example of an Impl class for the Person entity.
 * @BusinessEntity
 *   (tableName = CI_PER,
 *    oneToManyCollections  = { @Child( collectionName = names,
 *                                 childTableName = CI_PER_NAME,
 *                                 orderByColumnNames = { SEQ_NUM } )
public class Person_Impl
    extends Person_Gen {
     * @return the UI Display "info" for this person
    public String getInfo() {
        return "PrimaryName: " + getPrimaryName().getInfo();
Important parts of the implementation class are described below:
The implementation class name must end with the suffix_Impl. For example, if the entity has apersonname, then the implementation class name would besome.package.Person_Impl. This also means that the generated business interface will be named assome.package.Person.
A Class Annotation which declares: - What table this entity represents.
- What the owned-child tables are and what they should be called.
- Other information. Please see the BusinessEntityAnnotationclass for more details.
The class extends an abstract superclass having the suffix of
_Gen. Continuing the example of an entity with apersonname, the implementation class would extend a not-yet-created abstract superclass namedsome.package.Person_Gen. This superclass is created by the artifact generator based on metadata about the table and contains:- Getter methods for properties, including parent objects and collections.
- The getDTO()andsetDTO(...)methods that allow for properties to be changed.
- Access to standard framework methods like createQuery(...).
Business methods. Any hand-coded public methods are automatically exported
onto the generated business interface (for example,
some.package.Person). Client code can then access the added business method as follows:
 Person aPerson = some logic retrieving a person instance
 String thePersonsInfo = aPerson.getInfo();
- Constants. Any hand-coded public static final variables are automatically exported onto the generated business interface. This will be useful for constants related to the entity.
- Having created a new entity, it is likely that validation rules and other behaviors should be added to it. See Adding Change Handlers for more information.
