Data Objects
Both PageHeader and PageBody are "wrappers" on underlying Maps that hold datatypes of various types, keyed by field names (strings). The valid field names for a service are described in the service meta info file (an xml document). Null values are not allowed; use empty strings to represent missing values (for null date, for example).
Note that most system datatypes are represented in these Java objects as simple strings. Note the following:
  • Booleans are represented by the Java Boolean class.
  • Date values are represented as Strings in the format YYYY-MM-DD.
  • Date/Time values are represented as Strings in the format YYYY-MM-DD-HH:MM:SS.
  • Time values are represented as Strings in the format HH:MM:SS.
  • BigInteger values are represented as Java BigInteger values.
  • BigDecimal and Money values are represented as Java BigDecimal values, with the appropriate scale.
