Tailoring Templates and User Exits
The templates delivered under the folder $SPLEBASE/templates can be overridden by the application by creating a copy of the template file with the same name but prefixed by cm.. The cm copy will be customized.
Since the templates can contain user exits (special statements that allow to import external files during the template processing). Those user exits can be overridden by creating a copy of the user exit file with the same name but prefixed by cm_​. The cm copy will be customized.
