Using the applyCM Utility
After an implementation team has completed CM development on a Windows server or prepared a fix in a development environment, they will need to copy and apply the CM modules to a packaging environment on the same platform as the target (production or testing, for example). In other words, if the target system is a Unix platform, the packaging environment must be on Unix as well.
The
applyCM.sh
 utility (
applyCM.cmd
 for Windows
installations) serves this need. It can be used to copy and apply all CM development
modules to a packaging environment or any specific extract (patch) of CM development.
The script needs to be executed using the full pathname (this is necessary because you
need to be located in a different folder, see below). In addition, you need to be set to
a target environment (such as packaging environment).
Script: <CM scripts>/applyCM.sh
Usage:
(no options)
Apply the patch on top of the existing base product and possibly CM integration environment. This mode will add new CM files from the patch to the environment and replace the changed ones. But it will not delete the previously existing in the environment CM modules that are not part of the patch.
It needs to be executed from the source root folder.
-d
Remove all previous CM modules from the environment and apply patch on clean base product environment. This option is useful when needed to create the CM integration environment from scratch.
 -b
Recompile the existing sources in current environemnt. Usually it is used to execute full recompile a development environment.
It needs to be executed from the application folder root. For example:
$SPLEBASE.
-n
It will not stop/start automatically the target environment.
The input for applyCM.sh utility is the current folder (source root folder),
which contains the following subfolders:
- java
- scripts
- etc
- services
- splapp
These subdirectories contain only CM modules created according to the rules of the document
"Naming conventions for tailoring application implemetation" (see the Installation
Guide of the product). This directory structure should be prepared and filled
with relevant CM modules on development Windows server, then copied over to the server
that hosts a packaging environment by ftp utility. After that, you can apply the patch
to the packaging environment. Modules that are not created using these conventions
will be ignored by applyCM.sh utility. You have to reside in
the patch directory to apply the patch. ApplyCM utility will generate
and compile java code and create a java jar file (cm.jar), which is
required for customer implementation platform.
