Referencing URIs
There are some configuration objects that require a reference to a URI, including file path URIs. The following sections highlight some functionality supported by the product with respect to defining / accessing URIs.
In order for the functionality described below to occur, specific APIs must be used by the underlying code related to the fields that capture or process the file path or URL information. If you find that there is a URI-related field that does not provide the functionality described here, please contact customer support.
For schema elements in a business object that reference a
Field with the
URI data type or define the element with the
URI data type configured in the
schema will automatically use the appropriate API that validates the value that may reference a substitution variable or must be checked against the allowlist if applicable.
Parent topic
