Defining Redaction Rules
This portal is used to view and maintain rules that define how specific fields that containing personal information should be redacted when exported out of the application. For example, an e-mail address may be redacted by replacing some or all characters with ‘*’.
Refer to
Data Reaction on Export for more information.
You can access the portal from the >  > . You are brought to a query portal with options for searching for a specific redaction rule. Once a redaction rule has been selected you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main tab page
• Redaction Rule. This zone provides information about the selected rule.
Parent topic
