3 Opower Integration Hub Features
Opower Integration Hub includes an SDK, a set of APIs, a token generation service, and components of the Oracle Utilities Opower Platform.
- SDK: An integration Software Development Kit (SDK) to authenticate and execute API calls, as well as support the creation of content as modularized widgets. For information on embedding widgets, see the Oracle Utilities Opower Digital Self Service - Energy Management Embeddable Widgets Integration Guide.
- APIs: Access to Oracle Utilities Opower data and insights through the use of generally available APIs. Generally available APIs include both REST APIs and a single GraphQL endpoint. For information on the GraphQL resources, refer to the Oracle Utilities Opower GraphQL API User Guide. The following data and insights are available without AMI data:
- Usage data by bill period
- Costs data by bill period
- Disaggregation insights generated by Oracle Utilities Opower disaggregation models
- Bill comparison insights
- The data and insights listed below are available with AMI data. As described in Requirements and Limitations, utilities must purchase an additional AMI data integration fee to access these data and insights:
- Usage data by bill period, day, interval
- Costs data by bill period, day, and interval (day and interval costs data require additional cloud services and fees, as described in Requirements and Limitations)
- Bill comparison AMI-based insights Bill forecast insights
- Token Generation Service: A secure token generation service supports single sign-on authentication that allows Opower Integration Hub Partner integrations to embed Oracle Utilities Opower widgets in an Opower Integration Hub Partner portal, embed Opower Integration Hub Partner widgets in the Oracle Utilities Opower Energy Efficiency Web Portal, and access data through APIs.
- Opower Platform: The Opower Platform including data integration, analytical insights, and data dissaggregation.
