2 Requirements and Limitations
The following data requirements and limitations apply to all utilities using the Opower Integration Hub.
| Category | Description |
| Cloud Service Requirements | The Integration Hub Cloud Service must be purchased. The Opower platform must be set up in order to use the APIs described in Opower Integration Hub Features. Setting up the platform requires the Oracle Utilities Opower Customer Billing Integration and Platform Cloud Service Setup Fee.
The Oracle Utilities Opower AMI Integration and Platform Cloud Service Setup Fee must be purchased in order to obtain AMI data and insights through the APIs. The following cloud services must be purchased in order to obtain AMI cost data at daily and subdaily resolutions through the APIs:
| Implementation Requirements | You must complete data integration to use Oracle Utilities Opower data and insights with Opower Integration Hub. Data must be sent to Oracle Utilities in the right schema and according to the established data specifications. Your Delivery Team will work with you to identify which data specifications are applicable to your situation.
