2 Design and Configuration
The Oracle Utilities Opower platform allows for product configurations and customizations to meet the needs of each utility. A configuration is a simple change that can be made with no coding required. There are required configurations and optional configurations. A customization is a change that requires more in-depth technical work, design, or coding to alter the appearance or behavior of the product, or to create something new within the product.
This guide only provides a summary of configuration options. Customization options may be available for your program at cost as an Oracle Utilities Opower professional service offering. Ask your Service Delivery Manager how customization options could enhance your program.
If an element is not listed as a configuration, you should assume that it cannot be configured and would require a customization. Contact your Delivery Team if you have questions about this process or would like to make a customization request.
