Default Text and Options
Unless otherwise noted, Oracle recommends that you use the default text and options that are provided. These options have been chosen carefully by our copywriters and have been through user testing to maximize comprehension and effectiveness.
For the Load Shifting, Electric Vehicle features, each email is comprised of individual modules. It is strongly recommended that you use the default order of the modules, as the emails were designed to be read from top to bottom, to provide the reader with an easy-to-understand message about their energy use.
If you must configure an option to use something other than the default, be aware of the following:
  • While you can configure the text that appears, you cannot change the logic behind the text.
  • Using options and text other than the default could impact the effectiveness of your program.
The following sections discuss the default order of the modules, design, configuration options, and the user experience variations that are specific to these Load Shifting, Electric Vehicle features:
