EV Best Time Off-Peak Module
The Best Time Off-Peak module explains to the reader when the best times are to charge their electric vehicle (EV) during off-peak hours. The module explains how this behavior can ease the strain on the grid. This module is used only in the third introduction email.
Requirements
There are no module-specific requirements. For product requirements, see Requirements and Limitations for EV Charging Coach Emails.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-2 Configuration Options
| Configuration Option | Input Value |
Images The images can be configured to use client-specific colors. Other than that, the image can not be changed. |
Optional Specify client branding colors. |
Extra Mile Statement and Tip Text Utilities are encouraged to review the statements and tip text and adjust them to ensure that they are pushing customers to charge at the times that are most beneficial to the utility. |
Optional Specify one of the following:
To see how this module fits into the overall user experience, see Design and Configuration.
