Configuring Consumption Extract Type
This portal is used to display and maintain a Consumption Extract Type.
Refer to Understanding Consumption Extract Types for more information.
You can access the portal by selecting Admin, then Integration, then Consumption Extract Type.
- Consumption Extract Type List: displays all of the Consumption Extract Types so you can choose the one you want to display in more detail
- Consumption Extract Type: shows the specific configuration for the selected Consumption Extract Type
