Understanding Manufacturers
Manufacturers are the companies that makes devices.
A device's manufacturer is defined as an attribute of the device itself.
Each manufacturer can have zero or more models defined. Models for a single manufacturer can have diverse service types.
Models can specify an Exclude Command Set that references commands that are not eligible for that model. Refer to Understanding Command Sets for more information.
The Device Command Set Override field indicates if a command set defined by in Exclude Command Set field may be can be overridden and specified at the device.
