Non-Interval Usage to 'Plain' XML Mapping
The following table shows the mapping between fields in incoming non-interval data and child elements of MeterReads/MeterRead element in the "Plain" XML format:
L+G Interval Structure Field |
"Plain" XML element |
ID |
RecordType |
Premise ID |
Premise |
ESIID |
ESIID |
Provisioned |
Provisioned |
Meter |
MeterID |
kWh |
kWh |
Date/Time of initial Read |
FirstIntervalDateTime |
Peak |
Peak |
Peak Date/Time |
PeakDateTime |
Dmd |
Dmd |
TouA |
TouA |
TouB |
TouB |
TouC |
TouC |
TouD |
TouD |
TouE |
TouE |
Volts |
Volts |
PF |
PF |
ExtraFields/ExtraField/FieldName
with value of ExtraFields/ExtraField/FieldValue
with value in |
with value in |
with value in |
with value in |
RawData |
A record content from incoming file. |
