WSDLs, Endpoints, and Messages
WSDLs are Web Service Definition Language files that describe a web service. New services must utilize the WSDLs to determine the structure of requests and responses. For remote services, they contain the locations to access the services. For both remote and local (hosted) services, the files will contain the definitions for each web service including names, arguments, exceptions, and the structure of the input and output messages.
In Oracle Serivce Oriented Architecture (SOA), WSDLs can be classified as a “service” or as a “reference.” Services are hosted on the SOA server; that is, the implementation of the web service is on the local application server. Referenced services are implemented on a different server. This distinction is also relevant to the composite level. Services are implemented in the current composite. References are located elsewhere, possibly on the same app server, but in a different composite.
An “endpoint” is simply the URL for a web service. Since web services communicate via HTTP, each will have a unique URL. Once a service’s endpoint is known, a message service can be targeted to it.
How to locate WSDLs and Endpoints
There are two ways to locate WSDLs in an installed Adapter: through Enterprise Manager and by using a direct URL. Only “hosted” WSDLs can be located in this way. Referenced (remote) WSDLs must be either located in source code or obtained from the hosted location.
How to Use Enterprise Manager to Locate WSDLs and Endpoints:
Open Enterprise Manager and use the navigation pane to open the Dashboard of the desired composite.
The top bar of the Dashboard contains several buttons and icons. One of these is an “earth” icon with a puzzle piece over it. Click this icon to display the WSDL and endpoint URIs for the composite.
Click the URL link to see the WSDL in the browser, or right click and save it to your machine for use in developing new services.
Depending on the requirements, It may be necessary to download the associated schema or WSDL file(s). Schemas are available within the WSDL’s “types” element. Find associated WSDL URLs within the import element. That URL can be pasted into a browser tab.
The endpoint for the service is also visible in this window. It is this URL that should be added to message sender configuration. For example:
The value HTTP Header/SOA Action is taken from the service’s WSDL. Locate the wsdl:definitions/wsdl:binding/wsdl:operation/soap:operation element for the web method being invoked. An attribute called soapAction will contain the value for this field. A shortcut to this field is using Enterprise Manager's Testing framework (locate the Test tab from the dashboard view for the composite). Once the WSDL is parsed, the SOAP Action will appear in a field on the request tab:
The values HTTP Login User and HTTP Login Password should be set to a valid WebLogic user that has access to the module. The HTTP Method should always be set to POST and the HTTP URL 1 should be set to the value of the endpoint above.
How to Use a Direct URL to Locate WSDLs and Endpoints
The WSDLs can be accessed without Enterprise Manager by understanding the paths used on the SOA server. In general, they have the form:
http://{server name}:{port number}/soa-infra/services/{partition}/{Composite}/{Web Service}
