System Override Date Support
This section provides information on system override date support.
A System Date can be overridden at either system level or user level or both. SaaS Batch Scheduler supports the system date override at system level only. The scheduler batch streams are scheduled and processed including submitting batch jobs on the stream steps per system date override. Any online operations performed by user on the scheduler batch stream operations portal such as skip, pause, cancel etc are also processed per system date override.
Note: When system date is overridden, scheduler batch stream definitions
that are already scheduled and have next scheduled date set on them
do not automatically get the new scheduled date per the overridden
system date. This means the next run would be per the current date/time.
The overridden system date reflects on the subsequent runs after the
scheduler batch stream runs once. If the system override date needs
to take effect immediately, the stream’s schedule can be updated.
This reset/blanks out the next scheduled run so it gets determined
immediately per system overridden date.
