Configuring Manufacturers
This portal is used to display and maintain a Manufacturers.
You can access the portal by selecting Admin, then Device, then Manufacturer.
  • Manufacturer List: This zone lists all Manufacturer records. Broadcast a record to display the details of the selected record. Manufacturer: This zone provides information about the selected Manufacturer.
