Successful Termination
This rule allows VEE to be successfully terminated based on a list of exceptions.
Additional detail on the logic of this rule can be found in the Detailed Description of the D1-AVEER-EST Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D1-VEERuleSuccessTermination
