Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the Itron OpenWay application in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
 Inbound Web Service Name  |
 Description  |
 D1-BulkRequestHeader  |
 Bulk Request Header  |
 D1-BulkRequestUpdate  |
 Bulk Request Update  |
 D1-BulkResponse  |
 Bulk Response  |
 D1-DeviceEventSeeder  |
 Device Event Seeder  |
 D1-DeviceStatusCheck  |
 Device Status Check  |
 D1-InitialLoadIMD  |
 Used by OSB to instantiate an IMD  |
 D1-PayloadErrorNotif  |
 Payload Error Notification  |
 D1-PayloadStatistics  |
 Payload Statistics  |
 D1-PayloadSummary  |
 Payload Summary  |
 D8-DetLoadSideVoltageMtrRslt  |
 Itron - Detect Load Side Voltage by Meter Result  |
 D8-DisconnectMeterResult  |
 Disconnect Meter Result Service  |
 D8-InterrogateByGroupResult  |
 Itron - Interrogate By Group Result XIA  |
 D8-PingByEndpointsMDResponse  |
 Itron - Ping By Endpoints Multi-Device Response XAI Inbound  |
 D8-PingByEndpointsResponse  |
 Itron - Ping By Endpoints Response inbound web service  |
 D8-ReadDisconStateMtrRslt  |
 Itron - Read Disconnect State by Meter Result Service  |
 D8-ReadResult  |
 Itron - Contingency Read Result  |
 D8-ReconnectMeterResult  |
 Itron - Reconnect Meter Result Service  |
Note: The following apply to all of the above inbound web services:
Message Options
Trace: No
Debug: No
Active: Yes
Operations
Operation Name: Same as web service name
Schema Type: Business Object
Schema Name: Applicable business object code
Transaction Type: Add
