Configuring Device Event Notification Suppression
Oracle Utilities Meter Data Management includes the following components used when integrating with Oracle Utilities Network Management Systems:
Service Provider Processing Methods
The following processing methods should be associated to the service provider configured for Oracle Utilities Network Management System:
Processing Role |
Description |
Bulk Response |
This role will identify the appropriate message to send with the results of a bulk command execution. For example, this would be used if a large list of devices had been supplied to execute device status check in order to verify outage status. |
Response - Success |
This role will identify the appropriate message to send for a successful smart meter command |
Send Device Event |
This role sets up the subscription for device events that Oracle Utilities Network Management System has interest in. |
Suppression Notification |
This role identifies the appropriate message to send when a notification has been set or removed. |
Activity Types
The following processing activity types should be configured:
Activity Type |
Description |
Bulk Request Header |
Configuration for the bulk request header activity type which is used in making smart meter command requests for a list of meters. |
Bulk Response |
Configuration for the bulk response activity type which organizes the response for bulk requests. |
Device Event Notification Suppression |
Identifies the device event categories and types that are subject to suppression. |
