Configuring Device Event Types
This portal is used to display and maintain a Device Event Type.
Refer to Understanding Device Event Types for more information.
You can access the portal by selecting Admin, then Communication, then Device Event Type.
- Device Event Type List: This zone lists all Device Event Type records. Broadcast a record to display the details of the selected record.
- Device Event Type: This zone provides information about the selected Device Event Type.
