Ensure IMD Exists for Sibling MCs
This rule validates that an IMD exist for all of the other measuring components associated to the same Device Configuration as the current measuring component, for the same period of time.
A check is also performed that all of the Initial Measurements have the same External Source ID (indicating that they all came from the same usage file).
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-ENSIMDMC Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-EnsureIMDExistsForSibling
