Device Communication Base Package Business Objects
The Sensus RNI Adapter base package includes the following communication business objects:
Business Object Name |
Description |
D6-ConnectDisconStateChgNtf |
Sensus - Connect/Disconnect State Change |
D6-InitiateConnectDisconnect |
Sensus - Initiate Connect Disconnect |
D6-InitiateMeterByMeterId |
Sensus - Initiate Meter Read By Meter ID |
D6-InitiateOutageDetection |
Sensus - Initiate Outage Detection |
D6-MeterAddNotification |
Sensus - Meter Add Notification |
D6-MeterRemoveNotifcation |
Sensus - Meter Remove Notification |
D6-OutageDetectEvtNotification |
Sensus - Outage Detection Event Notification |
D6-ReadingChgNotification |
Sensus - Reading Changed Notification |
D6-UnsolicitedEvtNotification |
Sensus - Unsolicited Event Notification |
Sensus Event Data Mapping
The Sensus event file format maps as follows into the business object, D1-DeviceEventMappingLookup:
Sensus Flat File Field |
Device Event Seeder BO Element |
Comments |
Transaction ID (from Header record) |
External Source Identifier |
This is the file name. |
Device Identifier |
External Device Identifier |
Event Name |
External Event Name |
Event Creation Date/Time |
Event Date/Time |
Device Type |
External Device Type |
This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router |
Service Location ID |
External Service Location ID |
Communication Module Serial Number |
External Communication Module Identifier |
Event Category ID |
External Event Category |
Event Severity |
External Event Severity |
Valid values include (although the element itself is free-form): Alert Information |
Status Value |
External Status Value |
This represents additional information that relates to the event itself. |
Status Date/Time |
External Status Date/Time |
The date & time at which the additional information referenced above had occurred. |
