Device Communication Base Package Business Objects
The Silver Spring Networks Adapter base package includes the following communication business objects:
Business Object Name |
Description |
D7-AddMeterReadJobInterval |
SSN - Add Meter Read Job (Interval) |
D7-AddMeterReadJobScalar |
SSN - Add Meter Read Job (Scalar) |
D7-AddPingJob |
SSN - Add Ping Job |
D7-ConnectDisconnect |
SSN - Connect or Disconnect |
D7-ConnectDisconnectResp |
SSN - Connect or Disconnect Response |
D7-GetStatus |
SSN - Get Status |
D7-GetStatusResponse |
SSN - Get Status Response |
D7-MeterReadResponseInterval |
SSN - Meter Read Response (Interval) |
D7-MeterReadResponseScalar |
SSN - Meter Read Response (Scalar) |
D7-PingJobResponse |
SSN - Ping Job Response |
D7-ReplaceDeviceAtLocForDecomm |
SSN - Replace Device At Location (Decomm) |
D7-ReplaceLocation |
SSN - Replace Location |
Silver Spring Networks Event Data Mapping
The Silver Spring event file format maps as follows into the business object, D1-DeviceEventMappingLookup:
Silver Spring Flat File Field |
Device Event Seeder BO Element |
Comments |
Transaction ID (from Header record) |
External Source Identifier |
This is the file name. |
Device Identifier |
External Device Identifier |
Event Name |
External Event Name |
Event Creation Date/Time |
Event Date/Time |
Device Type |
External Device Type |
This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router |
Service Location ID |
External Service Location ID |
Communication Module Serial Number |
External Communication Module Identifier |
Event Category ID |
External Event Category |
Event Severity |
External Event Severity |
Valid values include (although the element itself is free-form): Alert Information |
Status Value |
External Status Value |
This represents additional information that relates to the event itself. |
Status Date/Time |
External Status Date/Time |
The date & time at which the additional information referenced above had occurred. |
