Defining Interval Price Set Types
You use the Interval Price Set Type portal to display and maintain interval price set types.
Refer to Understanding Interval Price Set Types for more information./
You can access the portal by selecting Admin, select Interval Price Set, then select Interval Price Set Type. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Interval Price Set Type: This zone displays basic information about interval price set type.
