Maintaining Asset Locations
You use the Asset Location portal is used to search for asset locations.
Refer to About Asset Locations for additional information about asset locations.
You can access the Asset Location portal from Menu > Asset Management > Asset Location. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the Service Point portal to view and maintain the selected record.
Note: In Oracle Utilities Customer To Meter, asset locations are created
and/or updated when a service point is created and/or updated. If
the service point has a contact associated with it, a corresponding
contact will be created for the asset location. See About
Contacts and Maintaining Contacts for more information about creating and
maintaining contacts used with asset locations.
