Configuring Extracts
Oracle Utilities Meter Data Management includes the following components used when integrating with Oracle Utilities Analytics:
Master Configuration
The following master configurations are used to configure the sync process between MDM and OUA:
Description
Analytics Master Configuration - ODI-Based
This master configuration is primarily used to configure the information that will be used in the extraction of data for business intelligence when using the Oracle Data Integrator extract, transform, and load (ETL) process.
Batch Controls
Batch Code
Name / Description
D1-SPSDL
Service Point Snapshot Download
D2-DUGDL
Usage Subscription Usage Calculation Group Download
D2-USGDL
Service Point Usage Snapshot Download
D2-UUSDL
SP Unreported Usage Snapshot Download
D2-VEEDL
SP VEE Exception Snapshot Download
