Configuring Settlement Units
Refer to Understanding Settlement Units for more information.
You can access the portal by selecting Admin, then Settlement, then Settlement Unit. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Settlement Unit: This zone displays details for the settlement unit, including configured dimensions.
 - Settlement Unit Dimension Combinations: This zone displays combinations of the settlement unit’s dimensions, based on the dimensions configured in the Settlement Unit zone. Click Add Dimension Combination in the zone’s title bar to add a new combination.
 - Settlement Unit Valid Factors: This zone displays valid multi-variable factors for the settlement unit. Click Add Factor in the zone’s title bar to add a new factor. Values for these factors are defined on the Multi-Variable Factor tab.
The following zones appear as part of the portal's Dimension Combinations tab page:
- Settlement Unit Dimension Combinations: This zone displays a list of dimension combinations for the settlement unit. Broadcast a record to display the details of the selected record. Click Add Dimension Combination in the zone’s title bar to add a new combination.
 - Dimension Combination Values: This zone displays factor values for each multi-variable factor defined for the selected dimension combination. You can use this zone to add and/or edit factor values.
The following zones appear as part of the portal's Multi-Variable Factor tab page:
- Multi-Variable Factor List: This zone displays a list of multi-variable factors for the settlement unit. Broadcast a record to display the details of the selected record.
 - Multi-Variable Factor Value List: This zone displays factor values for each dimension combination for the selected multi-variable factor. You can use this zone to add and/or edit factor values.
