Defining Action Methods
Refer to Action Method for an overview of action method functionality.
To maintain the action methods applicable to your implementation, open Admin > System > Action Method.
This is a standard All-in-One portal and includes the standard List and display zones for an action method.
The information captured on the action method depends on the business objects supported by your product or implementation. Refer to the embedded help text for more information.
