Configuring External Applications
This portal is used to display and maintain External Applications.
Refer to Understanding External Applications for more information.
You can access the portal from the Admin, then Integration, then External Application.
- External Applications List: This zone lists all External Application records. Broadcast a record to display the details of the selected record.
 - External Application: This zone provides information about the selected External Application.
 - Processing Method List: This zone provides the list of processing methods defined for the External Application.
 - Translation Method List: This zone provides the list of translation methods defined for the External Application.
 - Inbound BOs Send By Service Provider: This zone lists inbound Business Objects that are sent by this External Application. The identification is driven by the Business Object having a Business Object Option of type "Sent By Service Provider" that references the current External Application.
