Dynamic Comparison Validation
This validation rule compares measurements to historical statistics for the related Service Point. The system will maintain statistics such as the following: sum, min, max, average, median, zero value count, outage count, and standard deviation. Setting up these Measuring Component Statistics is a prerequisite to using the rule.
- Lowest/highest usage ever
 - Current usage is more than three standard deviations from the mean
 - Detect unexpected zero usage
 - Detect negative usage while ruling out known cases
 - Abnormal usage
 - Voltage threshold monitoring
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-DYNCOMCHK Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-DynCompValidation
Example Scenarios
Below are some example scenarios that can be achieved based on configuration of this rule.
Example 1: Detect new "high water mark"
Example 2: High Usage
Example 3: Detect unexpected zero usage (method 1)
Example 4: Detect unexpected zero usage (method 2)
Example 5: Detect negative usage while ruling out known cases
Example 6: Abnormal usage
Example 7: Voltage threshold monitoring
