Field | Comments |
Userid | This is the unique user identifier used within the product used for authorization activities. Limited to eight (8) characters in length. |
Login Id | This is the unique user identifier used within the product used for authentication purposes. This must match the value used in the security repository to successfully use the product. Limited to 256 characters in length. This value can be the same or different to the Userid. |
Last Name | Last Name of user. Limited to 50 characters in length. |
First Name | First Name of user. Limited to 50 characters in length. |
User Enable | Whether the user is active in the security system or not. Valid Values: Yes (default) – User is active and can use the system, No – User is disabled and cannot use the system. Refer to User Enable and Disable for more details. |
User Type | The type of user. Valid Values: Blank = Normal user, Template = Template Users. |
Language | Default Language used for user. For non-English languages, Language pack must be installed to use specific languages. |
Display Profile Id | The display profile associated with the user. This controls the display of currency, dates, and so on. |
Time Zone | Time Zone allocated to user account. Note: This feature is only applicable to specific products. Check your product online documentation for more details about applicability. |
Email Address | Optional Email address associated with user. This is used by utilities and can be used for interfaces requiring email addresses. |
Dashboard Width | Default width for Dashboard Portal. Setting this value to zero (0) will disable the dashboard altogether. |
Dashboard Location | Preferred location of the Dashboard Portal. This capability is only enabled for relevant platforms only. |
Dashboard State | Preferred initial state of the Dashboard Portal. This capability is only enabled for relevant platforms only. |
Home Page | The default home page associated with the user. |
Portals Profile User Id | The userid used to inherit portal definitions from. Refer to Template Users for more information. |
Favorites Profile User Id | The userid used to inherit favorite definitions from. Refer to Template Users for more information. |
To Do Summary Age Bar | The settings for the color coding of the To Do Summary portal in the dashboard. This can be used to indicate relative age of to do entries. |
User Groups | This is a list of user groups and their associated expiration dates. Refer to Defining Users to User Groups for more information. |
Zone Preference | Description |
Display | Whether the zone is included or not in the portal. This allows specific zones to be displayed at startup time while other zones can be hidden and only displayed upon conditions in other zones. See Zone Visibility in the online Administration guide for more information. |
Initially Collapsed | Whether the zone is displayed collapsed on initial load. Zones are only executed when they are expanded. Marking zones as Initially Collapsed can prevent them from being executed and can speed up portal rendering times. |
Sequence | Defines the relative order of the zones within the portal. A value of zero (0) takes the default sequence from the portal definition. |
Refresh Seconds | Defines the zone auto refresh rate (this is only applicable to a subset of zone types). A value of zero (0) disables auto-refresh. |
Security Access | This is an information field that indicates whether the user has access to the zone or not (while unlikely, it is possible to have a portal contain zones not permitted for access to an individual user). Refer to the online documentation for more information. |
Field | Description |
Sequence | Internal sequence used for sorting. |
Name | The name of the bookmark. The URL for the bookmark is hidden and not editable. |
Sequence | The relative sequence number of the favorite link used for sorting purposes. |
Navigation Option | The Navigation Option to display the favorite links. This can reference the zone or maintenance function to display after selecting the favorite link. |
Security Access | Indicates whether the Navigation Option is accessible or not to the user. |
Sequence | The relative sequence number of the favorite used for sorting purposes. |
Script | The BPA Script to use in order to display the favorite function or menu items. |
Security Access | Indicates whether the BPA Script is accessible or not to the user. |
Characteristic Type | The characteristic type associated with the User object. This is a drop-down list of the valid characteristic types associated with the object. |
Sequence | The relative sequence number of the characteristic used for processing purposes. |
Characteristic Value | Depending on the configuration of the Characteristic Type, this value may be free-formatted, an attachment, in a specific format or a specific set of values. |
Setting | Description |
Application Service | The unique identifies of the Application Service used in configuration of security on objects, menus, services, and so on. For custom definitions, Oracle recommends adding a “CM” prefix to distinguish these from Application Services provided by Oracle Utilities Market Settlements Management. |
Description | A brief description for documentation purposes that appears on security screens when the Application Service is specified. |
Access Modes | Lists the valid modes to access the Application Service. The modes must match the internal actions supported by the objects used by the Application Service. Use the Add icon to insert an Access Mode. Note that an Access Mode can only be defined once on an Application Service. Use the Delete icon to remove an existing Access Mode from the list. The Access Mode link to the Application Service is ownership-controlled and by default all created links are owned as Customer Modifications. Refer to Data Ownership Rules for more information. |
Zone | Description |
Application Service Details | Summarizes the Access Modes and Security Types of the Application Service. |
User Groups With Access | Lists the User Groups with access to the Application Service, along with the associated expiration dates, Access Modes, Security Types and associated authorization levels. Use the Deny Access function to limit the access of User Groups to the Application Service. |
User Groups Without Access | Lists those User Groups without access to the Application Service. Use the Grant Access function to allow User Groups to access the Application Service. |
Expiration Date | Specifies the date when access to the User Group expires. |
Access Mode | Shows the Access Mode as defined on the Application Service definition. Use the Add icon to insert an Access Mode or use the Delete icon to remove an existing Access Mode from the list. |
Owner | Ownership of link. Refer to Data Ownership Rules for more information. |
Security Type | The Security Type code associated with the Application Service. Use the Add icon to insert a Security Type or use the Delete icon to remove an existing one from the list. |
Authorization Level | The Authorization Level assigned to the User Group when running the Application Service for the Security Type. |
Expiration Date | Indicates the date on which access to the User Group expires. |
Access Mode | Valid Access mode as defined on Application Service definition. Use the Add icon to add a new Access Mode or use the Delete icon to remove an existing Access Mode from the list. |
Owner | Ownership of the link. Refer to Data Ownership Rules for more information. |
Authorization Level | The Authorization Level assigned to the User Group when running this Application Service for the Security Type. |
User | The authorization user identifier to associate with the user group. |
Expiration Date | Indicates the date on which the association between the user and the User Group expires. |
Default Access Group | When this user creates a new object that is subject to Access Security then this default is used for the value of the Access Group of the new object. This can be overridden by logic within the object if necessary. |
Data Access Role | List of Data Access Roles this user is attached to. |
Expiration Date | Indicates the date on which the association between the user and the Data Access Role expires. |
Value | Implications |
Enable | • The user can access the system. • The user can process records according to the authorization model. • The user must be active in the Security Repository to fully accessOracle Utilities Market Settlements Management. |
Disable | • The user cannot access the system regardless of the security setup. • The user record is retained for audit purposes only. • The user does not have to exist in the Security Repository. • The key use cases for this option are as follows: • Support for personnel (permanent or temporary) leaving: Manually deactivate users once they leave the organization yet keep the information for auditing purposes. • Logical deletion: If the user needs to be deleted for any reason, selecting this option removes the user record, preventing access to the system. • Temporary disablement: If business rules need to isolate the user record, selecting this option for the appropriate users can effectively deactivate their access to Oracle Utilities Market Settlements Management. Note: Deactivation of the user record will take effect when the user logs in to the system or after the security cache refreshes. |
