Apply Math (Interval Data)
This rule is used to perform calculations on interval data and it stores the results in the usage transaction's service quantities. A variety of options are available on this rule that include defining the calculation type, variables to use, as well as the equation to use (math functions and expressions).
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-APPMATHIN Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-ApplyMathInt
Example Scenarios
Below are some example scenarios that can be achieved based on configuration of this rule.
Scenario 1: Get the total KWH for the period
Calculation Type = Single Variable
Variable Name = V1, where the following is configured:
  • Variable Type = Channel Accumulation
  • UOM = KWH
  • Set Function = Sum
Scenario 2: Get the higher value between the total KWH or total KVARH
Calculation Type = Math Function
Math Function = Max
  • UOM = KWH
Variable Name = V2, where the following is configured:
  • UOM = KVARH
Scenario 3: Total KWH multiplied with a factor value
Calculation Type = Mathematical Expression
Mathematical Expression = V1 * V2
  • UOM = KWH
  • Variable Type = Factor
  • Factor = factor code that holds the multiplier
