Maintaining Usage Subscriptions
This portal is used to display and maintain a Usage Subscription.
You can access the portal from Menu > Usage > Usage Subscription. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Usage Subscription: Defines basic information about the usage subscription, including factor overrides, usage calculation groups, and service points.
  • Usage Subscription Market Participants: Lists market participants associated with the usage subscription (via Usage Subscription Market Participants)
  • Sub Usage Subscriptions: Lists the first fifty "sub" usage subscriptions for the master usage subscription displayed in the Usage Subscription zone. This zone is only displayed for "master" usage subscriptions.
