Using 360 Degree View Device
This portal is used to view a broad set of information related to a Device.
You can access the portal from the Main > 360 Search > [options]. You are provided with the option of searching by Name, Address, or Device. Once a Device has been selected you are brought to the 360 Degree View Device portal.
The following zones may appear as part of the portal's Device tab page:
  • Device Overview: Displays the device, Service Point, Install Event, and Usage Subscription for the selected device.
  • Device Configuration Overview: Displays an overview of the device's configurations over time, including the measuring components associated with each configuration, and Service Points (along with the relevant Install Events) at which the device's configurations have been installed.
  • Scalar Readings: Displays a list of scalar readings for scalar measuring components associated with the current device and Device Configuration.
  • To create a new reading for scalar measuring components associated with the Device Configuration, click New Reading.
  • To edit an existing reading, click the edit icon for the reading you wish to edit. Editing a reading creates new initial measurements that are validated. If these edits do not pass validations, including VEE Rules, the changes are not saved.
