Using 360 Degree View Measuring Component
This portal is used to view a broad set of information related to a Measuring Component.
You can access the portal from the Main > 360 Search > [options]. You are provided with the option of searching by Name, Address, or Device. Once a Measuring Component has been selected you are brought to the 360 Degree View Measuring Component portal.
The following zones may appear as part of the portal's Measuring Component tab page:
  • Measuring Component Overview: Displays the Service Point, device, Device Configuration, Install Event, and Usage Subscription for the selected device.
  • Device Configuration Overview: Displays an overview of the measuring component's parent device's configurations over time, including the measuring components associated with each configuration, and Service Points (along with the relevant Install Events) at which the device's configurations have been installed over time, if any exist.
  • To create a new reading for a scalar measuring component associated to a Device Configuration, click the New Reading link in the zone title bar.
  • Interval - Initial Measurement Overlay: Overlays initial interval measurements (either pre-VEE or post-VEE) against the final measurements for a given period in graphic and tabular formats.
  • Final Values Overlay: Graphs final measurements for a measuring component, and provides the ability to overlay the graphed data with final measurements from other measuring components. The zone also permits overlaying data from the same measuring component for different time periods, as well as data from measuring components that measuring different quantities, such as temperature.
  • Interval - Audit View: Allows users to view an interval measurement curve for a given period overlaid with the count of audit records for each individual measurement. It also allows users to magnify a portion of the curve and see how the measurements looked at different points in time.
  • Time of Use By Day: Displays daily TOU-mapped usage data for an interval measuring component based on a user- defined time period and TOU map.
  • Time of Use Overlay: Displays an overlay of the TOU periods on a final interval measurement along with totalized TOU consumption based on a user-defined time period and TOU map.
  • Scalar - Initial Measurement Overlay: Overlays initial scalar measurements (either pre-VEE or post-VEE) against the final measurements for a given period in graphic and tabular formats.
  • Scalar - Audit View: Allows users to view a scalar measurement for a given period overlaid with the count of audit records for each individual measurement. It also allows users to magnify a portion of the measurement and see how the measurements looked at different points in time.
  • Measurements: Displays measurement details for the current measuring component in a tabular format. (split into two zones for v2.2)
  • Usage Subscriptions Directly Linked to MC: Displays Usage Subscriptions that are directly linked to current measuring component.
